10-16-2008, 05:18 PM | #1 |
71' Custom 10 (ole blue)
what cam should I get?
I'm rebuilding my 350 4 bolt main, it's been bored .30 over. I need a cam, not a full cam but something better than stock. what cams can I use that wont mess up my transmission. Its got a turbo 400 and I don't want to touch it. I don't want to buy a torque converter or nothing. so can yall help me out?
10-16-2008, 05:44 PM | #2 |
Re: what cam should I get?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-16-2008, 06:32 PM | #3 |
first thing you need to do is get all your specs //tire sze gear ratio engine specs compression type of heads valve size springs etc you also need the weight of the vehicle//then you need a realistic assessment of how the vehicle will be used and how much you have to spend
after getting all that stuff written down call a cam hotline or two and talk to the cam guys to find what they have available for your needs and budget// crane and compcams are 2of the better tech lines that i've talked to
10-16-2008, 11:55 PM | #4 |
I'm a poor spectator
If your just looking for something a tad better than stock I wouldn't even bother calling anyone up trying to get some perfect cam for your truck. If you were going all out race then yeah call em up and get some advice or possibly a custom cam but in your case I would personally go with the Edelbrock performer cam or something compareable. Everyone will have their own opinion but i've got one of these and I think it runs great in an otherwise stock motor. I almost went bigger but i'm really glad I didn't. Between the stock cam and this one, I noticed a big difference.
http://www.edelbrock.com/automotive_...chevy_sb.shtml
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 10-16-2008 at 11:56 PM. |
10-16-2008, 06:25 PM | #5 |
I am a Referee of life.
Any good cam company will have tech support.They will ask
engine.intended use,weight of vehicle.tranny,gear ratio,heads,tire size,and probably about a dozen other questions.All this info helps them give you a good recommendation.The more info you give the happier you will be with the results.Remember to break it in exactly according to the instructions.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-17-2008, 09:35 AM | #6 |
Senior Moment
All good advice. More good advice STAY AWAY FROM COMP CAM
just my 2c. Nuff said
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
10-17-2008, 07:17 PM | #7 |
72 Chevelle Club
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
10-17-2008, 10:03 PM | #8 |
Whats wrong with comp cams??? I've run on for three years and still going.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
10-17-2008, 11:03 PM | #9 |
72 Chevelle Club
First I'm glad you have had great luck I have had 6 of them go flat in 5 motors and I used all comp assembly lube and break in add. in the oil . When I called them they said since I wasn't a profesional engine builder they were going to do nothing . So that's my experience maybe I just have bad luck . I'm not saying comp is bad only that I won't use them again based on past experience and the customer service sucks !! I now use Isky and have had zero problems. My 2 cents
10-17-2008, 11:16 PM | #10 |
Hand Crafted C-10
A mild RV cam should do; a little more performance and a pleasant lump.
I use a 268 in my 327... my .02 |
10-17-2008, 11:30 PM | #11 |
What?
I've run Comp Cams in many motors with zero proplems, and have never had to call the CS to complain. On a side note, I am planing a cam/head/intake upgrade on a 07 C6 LS3 from Lingenfelter (GT11). Guess who does the cam? Comp Cams... Not pickin an argument here, just makin a point that my experience has been all positive and still a customer.
Really, brand loyalty all aside... DO YOUR RESEARCH. In my case I have had good experiences, and I like the grind ratio's that Comp cam's offer it's customers. I remember when Erson cam's got a ton of bad press about being of poor quality, I am here to tell you that I am still running an Erson TQ20 cam after almost 15 years of hard driving. Just thowin in my .02
Chris 1968 K20 Suburban 1972 K10 LWB PU |
