10-17-2008, 09:03 AM | #1 |
Tot Roddin'
67-72 SWB Frame Differences?
EDIT 2wd SWB differences
I think I might try to locate another '72 frame to begin my build up, but was curious if there's any differences between the 67-72 SWB frames. Are they pretty well the same across the years? I'm building a '72 SWB, and would like to locate a '72 frame, but I wanted to see if I will be able to broaden my search field to the other years they were offered. Thanks for any help! Nate
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 10-17-2008 at 09:19 AM. |
10-17-2008, 09:19 AM | #2 |
Tot Roddin'
Re: 67-72 SWB Frame Differences?
Sorry guys I failed to mention this is for 2wd.
I know there will be a difference in the 2wd and 4wd frames, but mainly looking at any difference in the 67-72 2wd SWB frames.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-17-2008, 09:40 AM | #3 |
Junior Member
The only difference I know is that the ' 67 does not have the dimple for the steering box.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
10-17-2008, 09:44 AM | #4 |
Under Construction
I agree. get ya one and get started..... good luck with your search...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
10-17-2008, 01:09 PM | #5 |
the 67 and some of the early 68 frames (mine) didnt have the dimple nor did they have the provisions for a big block, i had to cut part of the top of the frame to clear my headers.
10-17-2008, 01:49 PM | #6 |
Tot Roddin'
Long time no see lost wages! I caught your truck in downtown JC at the cruise. It looks good as always!
Thanks for the info!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 10-17-2008 at 01:49 PM. |
10-17-2008, 03:55 PM | #7 |
67/68 have smaller holes in the core support mounts and use different bushings.
10-17-2008, 11:23 PM | #8 |
Tot Roddin'
So from what I've gathered:
67 - no PS pump dent/smaller core support mounts/different bushings 68 - smaller core support mounts/different bushings 69-72 - fairly the same This will help broaden my search for a good SWB frame, to hopefully begin my restoration. Thanks for your help, and any other info is appreciated!
10-18-2008, 10:03 PM | #9 | |
The Older Generation
Nate, The indentation is for the steering gear not the pump.... LockDoc
10-20-2008, 07:15 PM | #10 |
Tot Roddin'
Thanks for the correction LockDoc!
10-20-2008, 08:02 PM | #11 |
its all about the +6 inches
also, the metal used starting in 71 was a stronger steel. Per GM's records, 70 and older should not be heated up or drilled, while 71 and up is OK to do so.
We have prooven time and time again that it is OK to heat and drill the older ones, but the steel is still stronger on the later ones. Otherwise... what they said. |
10-20-2008, 08:12 PM | #12 |
Tot Roddin'
Thanks Andy!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 10-20-2008 at 08:13 PM. |
