10-21-2008, 05:42 PM | #1 |
79 K30 Mileage & Transfer case question?
OK guys,
I am looking at a 79 K30, 454/400, SRW, Full-Time four wheel drive crew cab with about 45,000 miles on it. My question is what type of mileage do you think I should expect? 10 MPG? Second, any suggestions on how to test to see if the transfer case is working in the "lock" mode? I am also not really sure what the lock mode means. What is the difference between when I am driving arounf in regular 4HI and 4Hi locked? Any help would be appreciated.
1972 GMC K1500, sbc 350, turbo 350 Castle Rock, CO |
10-21-2008, 07:24 PM | #2 |
Re: 79 K30 Mileage & Transfer case question?
8 if if you are lucky
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
10-21-2008, 07:29 PM | #3 |
I put the mile marker kit in my NP203, still only got 10mpg downhill. What abe said, you are looking at an 8-10 mpg truck. NP203 info
10-21-2008, 08:02 PM | #4 |
Wow, I am shocked it is so low. Can either of you guys tell me what the difference is when the transfer case is in lock mode?
If you had to do it again would you put the mile marker kit in?
10-21-2008, 08:09 PM | #5 |
Junior Member
I think you should pass on it and give me the info!!!!! My commute is really short!!!
10-21-2008, 09:10 PM | #6 |
Workaholic
I could very well be wrong but I thought the K-30 came with a NP205 transfer case (which is a a part time 4wd unit). Maybe that was just the manual tranny versions.
Anyways, if it were me, I would set my mpg expectations at 8-12. . . . just my opinion/experience
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
10-21-2008, 09:29 PM | #7 |
This one definately has a full-time transfer case. Believe those are the 203s. Do you know what happens in 4 HI Lock versus 4 HI?
10-21-2008, 10:25 PM | #8 | |
The 203 units have a planetary arrangement in the case that allows for the front output and rear output to spin at slightly different speeds. This prevents torque windup in the driveline caused by the front wheels which often would turn faster/further than the rear due to cornering. When you pull the lever to Lock mode it engages the planetary front side and keeps the outputs spinning the same speed. Back in the 70's when most of the full time units got part timed we would put a pipe nipple with an ell (pointed up) into the case oil fill hole. This would allow some over-filling of the case with straight weight 30 motor oil which allowed splash lubrication. With free wheeling lockouts installed and the lever in high, not locked, the gears/chain for the front output did not turn. I never had a problem with any that I converted. Part way through the 78 model year the chains and gears were narrowed a half inch. The teeth pitch was increased which negated slippage after some chain stretch and were more reliable than the earlier units. No 454 engines in 1979 GM K series trucks. I would have ordered one if it had been available! I did replace my 400 SB with a 454 also. Last edited by Dooley; 10-22-2008 at 11:34 AM. |
10-21-2008, 09:55 PM | #9 | |
Good luck, Joe |
10-21-2008, 10:18 PM | #10 | |
Wrong! The 1979 K30's with auto transmission were equipped with the full time 203 transfer case. They did not come with a 454 as the 400 smallblock was the biggest engine available in the 4x4x's from GM through the 1980 model year. The 454's became available in K30 series in 1982. I bought a new 79 K30 dually. I mounted Husky Selectro hubs and installed a SAE Engineering part time kit purchased from Midwest 4x4 in mine. The 205's came with them starting in 1980. You would have to accept 7-10 mpg if you want it. Last edited by Dooley; 10-22-2008 at 12:22 AM. |
10-21-2008, 10:22 PM | #11 |
Joe,
I am not an expert. But this truck was 100% stock, and I find it hard to imagine that the P.O. would go to the trouble to switch hubs, transfer case etc. I would have to image that some 79 K30 Crew Cabs SRW 454/400 models must have had another option. I also read that with the milemarker kits you have to put it in 4wd every 200 miles or so to allow for proper lubrication of the bearings in the case. Have you heard the same?
10-21-2008, 09:40 PM | #12 |
Lock is for 4-wheeling, not driving on the road if I remember correctly. Since it seems to be full time, its only got high, high lock, and low lock right?
