Old 10-22-2008, 10:42 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
one piece oil pan gasket question
when using a one piece oil pan gasket, do you use silicone?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 10-22-2008, 11:08 PM   #2
shovelhead
Re: one piece oil pan gasket question
If I remember right, you just use it in the corners. I just did this a couple of months ago, but can't remember. Good luck to you.
Shovel
shovelhead is offline   Reply With Quote
Old 10-22-2008, 11:24 PM   #3
thesteppenwolf
Question Re: one piece oil pan gasket question
..personally, I am a chicken....I silicone everything...
thesteppenwolf is offline   Reply With Quote
Old 10-23-2008, 07:36 AM   #4
70GMCer
70GMCer's Avatar
Just on the corners as per instructions from Felpro
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-23-2008, 12:33 PM   #5
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
My two cents:
Generally speaking, if you have a gasket, you don't need any silicone or sealer. This is true for water pumps, thermostats, pan gaskets . . . pretty much anything. The only thing I use is a spot or two of 3M trim adhesive to stick stuff in place, then assemble it dry.
The exceptions to the rule are:
1) where gaskets turn corners, like on a pan gasket where it goes around the rear main cap, or on an intake manifold at the corners of the lifter valley. Put one blob of silicone at the corners. So on your Fel-Pro pan gasket, put it just at the corners like it says to.
2) where separate gaskets meet, like on a multi-piece pan gasket. Put a blob of silicone at every junction point.
And use black silicone. It'll visually disappear as soon as it's all together. I've always thought it looked pretty cheesy to pop open a hood and see a big, bright blue silicone booger tracking around on the engine somewhere.
Lugnut64052 is offline   Reply With Quote
