Big Block engine swap
How hard is to swap a big block into these trucks. I know that I've seen it before. But just don't know what kind of mounts to use or where to locate them on the frame. And anything else that might be involved. Or potentail headaches.
Built 4 Speed
Re: Big Block engine swap
Beauty of chevy a 4.6 and a 9.3 will fit in the same mounts just about.
simply put no its not that hard if you have a complete motor to drop in. "common" issues will be radiator Exhaust front springs. really depends on how stout of a engine you are throwing in, but everything from the back of your crankshaft to your wheel studs could also factor in. for those who are guessinga 9.3 is a 572. whats a 10.3?
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" Last edited by d10s69c10; 10-24-2008 at 01:11 AM. |
The engine I'm currently looking at is a 396 with stock internals and the usual bolt-ons(intake,carb, headers and a decent cam). I'm not looking to get to crazy here as my truck is planned to be a daily driver with an automatic overdrive tranny. I guess the question I was trying to ask is, Is it just a matter of changing the mounts and dropping in the engine. Or is it more involved?
#4 | |
Hollister, CA.
![]() Join Date: Sep 2006
Check with CHEVYFLEETSIDE....he is currently working on one on his back-burner.....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
thanks for the info as I've not been able to find it anywhere else on the net.
Here is my thread so far. You don't have to go as far as cutting the firewall. That was a personal choice. http://67-72chevytrucks.com/vboard/s...d.php?t=259536
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
I have a 402 in mine. I cut the fire wall, made the cut out wider and deeper. I also trimmed the frame about 3/4 of an inch and modified my motor mounts to clear the manifolds.
Here's my 454.
I had to get some 68-72 big block frame mount towers to fit the header on the driver side (#2 tube was hitting the small block tower). I mounted mine on the forward holes on the frame rails to clear the firewall with teh valve covers. I'll have to have a driveshaft cut to fit. Requires some patience, but it can be done. |
Sorry about the picture still learning.
Dr. Frankenstein
10.3 is a 632ci? i might be wrong but im sure 604ish is about 10L so somewhere in there (im probably wrong but im only 19 so i usually am
I Wanna Go Fast!! |
