Old 10-24-2008, 04:59 PM   #1
38chevyhotrod
38chevyhotrod's Avatar
How much lowering on a 71 suburban (pictures please?)
I have a 71 suburban from which de springs were heated(by previous owner) so the burb dropped a few inches.
No i have never see the original ride hight, to have an idea of how much it really dropped.
because the burb drives really crappy with these springs i want to order a set of lowered springs. But i don't know how it looks with the different drop sizes.
1 inch isn't enough, but i would like to see the 2 or 3 inch dropped suburbans just to get an idea what to expect.
this is how mine is right now with the crappy springs.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 10-24-2008, 06:13 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: How much lowering on a 71 suburban (pictures please?)
Looks to me like you have a 2/4 but someone with one would probably know better.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-27-2008, 12:58 PM   #3
Hart_Rod
Hart_Rod's Avatar
I agree, probably 2/4.
Hart_Rod is offline   Reply With Quote
Old 10-27-2008, 02:44 PM   #4
38chevyhotrod
I can only get up to 3" lowering springs.
This means that he will always be a little lower on the nose.
I'd rather have him sitting nice level.
Old 10-27-2008, 11:06 PM   #5
AzDon
AzDon's Avatar
Look at the side profile pic.... the tires are the same gap from the top of the wheelwell.... the nose is lower because GM put taller wheelwells on the front, meaning the nose-down stance is what the designer intended. Your stance is perfect for that wheel/tire combo... if you want lower you will need to pull the wheels/tires inward (narrower or different backspacing/offset).
I'm not going to imply that there is only one right way to do this... What I would do is get quality heavy-duty replacement springs (like Moog) from a good part store and install. Measure the loaded height for the amount of desired drop and also measure the distance between coils (loaded). I'd then uninstall the coils and cut the number of full coils necessary to get the desired drop. You MUST cut only full, 360 degree loops out of the coil so that it will fit the pockets properly. The rear coils cannot be done this way because they have specifically sized and shaped top and bottom loops for mounting purposes. Best to replace these with stock springs and use lowering blocks between the axle tubes and the suspension arms. These can be made from square or rectangular thick-wall tubing.
AzDon is offline   Reply With Quote
Old 10-28-2008, 04:29 PM   #6
38chevyhotrod
I found this on the web, i think this would also count for the suburban.
Only the amount of drop i am unsure of.
I don't really want to mess with the standard springs, i have such springs on it and that doesn't drive very well.
Old 10-27-2008, 07:35 AM   #7
38chevyhotrod
Nobody els who can help me?
There must be somebody who can show me a picture of his suburban and tell me how much it is lowered.
Old 02-22-2009, 11:06 PM   #8
CG
BlahBlahBlah
I got my rear springs for my panel (same as the burb) from board vendor PICKMUP
Went to post a comparison photo between truck and burb springs but the board went down. Ill post em now.
Old 02-23-2009, 01:00 AM   #9
CG
BlahBlahBlah
Both styles...sorry couldnt get these to load in my other post.
Old 02-23-2009, 07:55 AM   #10
65sublime
65sublime's Avatar
CG, What are we looking at here? truck spring on the left, how much drop? Sub spring on the right,drop?
Thanks!
65sublime is offline   Reply With Quote
Old 02-23-2009, 11:01 PM   #11
CG
BlahBlahBlah
I believe these are both 4 inch drop. Truck on the left burb on the right.
