10-25-2008, 07:00 PM | #1 |
Plug for wire harness?
I'm getting ready to take my cab off the frame but need to remove the 4 wires that run to the back taillights. Does this just unplug from the firewall? It seems as it might but when I pull on it nothing pops out. I didn't want to damage anything so I didn't try too hard.
10-25-2008, 07:16 PM | #2 |
Re: Plug for wire harness?
It just unplugs as you suspected. If you pull on the lip it will help. Also spraying it down with a soapy solution and wiggling it around will loosen it up. There is a male plug on the inside that you should unplug before attempting to pull the outside plug out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-25-2008, 07:44 PM | #3 |
yep, that worked just like you said. Thanks
