10-26-2008, 03:46 PM | #1 |
Lifter removal fustration
I've decided to upgrade the cam and was expecting it to be pretty straight forward ( what a dreamer I am). None of the lifters want to come out of their bores. I can only assume that they have mushroomed and that is holding them back. What is the best way to deal with this? I really don't want to take the crank out. This is suppose to be a quick refurb. The motor is out of the truck and I have the pan off. HELP
Peter |
10-26-2008, 03:50 PM | #2 |
Re: Lifter removal fustration
If they will come up enough to remove the cam,pull it and remove them from the bottom.
10-26-2008, 04:06 PM | #3 |
Many times they are stuck from carbon buildup.
When trying to remove them spray them with carb cleaner. It will leak down the sides of the lifter and should aid in removal. You are right in the mushroom'ing effect as well. But that shouldnt be the bigger of the 2 issues.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
10-26-2008, 04:26 PM | #4 |
What?
Gum-Out carb cleaner has always been my friend when it comes to old lifter removal, that and a lifter removal tool that way you get a good grip on them.
That tool is something you can pick up just about anywhere, it's nothing exotic so you may even find it at a local auto part house.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 10-26-2008 at 04:26 PM. |
10-26-2008, 05:25 PM | #5 |
Well if they won't come out then they can go in. I pulled them up and they stayed in place while I removed the cam. I then took a screwdriver and tapped them back down and through. I counted 16 lifters that eventually came out so I should be good to go. Thanks for the help, I know I can always count on this group to come through.
Peter |
10-26-2008, 06:49 PM | #6 |
72 Chevelle Club
Check the lifter bores to make sure you can get the new ones in before you install the cam . Just a heads up in case you didn't think about it. Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
10-26-2008, 07:25 PM | #7 |
Why does it taste purple?
Autozone has a tool that you install on the top of the lifter and you screw the handle a little bit and it grabs the lock area of the lifter then pull up on the handle(think slide hammer,but tiny) and wah-lah,out comes the lifter
10-26-2008, 07:30 PM | #8 |
Has this same problem, they were just gunked up, had to remove from below. I didn't now about the tool, I will remember that~
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
