Vibration
Can bad wheel bearings or someting inside the diff case cause vibrations while driving at high speeds, lets say 40+ miles
Built 4 Speed
Re: Vibration
yes. any worno out bearing will allow play on any shaft and cause minor vibration worsening over time till it is violent.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
Re: Vibration
almost sounds like a driveshaft that's out of balance
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
Re: Vibration
The driveshaft still has the weights on. could engine timing cause any of this, cause it was way out, advanced
Il still change bearings on the rear axle |
Chevys Kick A$$
Re: Vibration
I was thinking wheel bearings or maybe bad u-joints?
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Re: Vibration
tires/rims?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: Vibration
How can the tires cause it?
Built 4 Speed
Re: Vibration
tires right off the assembly line are not perfectly balanced and neither are your average rims. so we apply lead wieghts wether it be clip or stick on to even out the centrifigul force. you will notice tires being out of balance as the wear and the vehicle always feels smoother when you get your tires rotated and such..
another culprit could be water in your tires from a bad seperator in your aircompressor. mud inside your rims. or even flat spots from the tires not being fully aired and sitting for too long between drives. driveshaft could be the culprit being bent but i dont think that is your issue.
