Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-27-2008, 01:35 AM   #1
Heavy Evy
born to lose
Heavy Evy's Avatar
Turbo headers/manifolds?
Does anybody know where I can get a set of sbc turbo header/manifolds? I tried to google it but came with all twin turbo stuff, I need single turbo. Any help would be much apperciated.
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 10-27-2008, 06:18 PM   #2
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Re: Turbo headers/manifolds?
you tie the headers together with a crossover pipe into the exhaust housing for a single turbo(twins get their own manifold/header)
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 11-07-2008, 01:38 AM   #3
LuckyHenriksen
LuckyHenriksen's Avatar
Do regular shorty headers work turned upside down, or do you need to re-weld flanges?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 11-07-2008, 02:46 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
I see some cast iron stuff for small blocks on Ebay now and then .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-16-2008, 03:56 AM   #5
allen57
i ended having to build my own setup since i couldnt find a kit.
allen57 is offline   Reply With Quote
Old 11-18-2008, 07:02 PM   #6
Heavy Evy
born to lose
Heavy Evy's Avatar
Im still looking into these as I haven't decided what im going to do yet. do you think single or twin turbo would be better for a daily driver/weekend warrior truck? thank you all for the replys.
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 11-18-2008, 09:57 PM   #7
71/454
Turbo Guy
71/454's Avatar
www.ssautochrome.com on ebay has them. They had kind of a bad rap on the turboforums. I decided I would try them because I could buy the pre made stainless ones for less than I could buy the mild steel make your own header kit pieces. Mine look really good and I have used them all summer on my truck.
As far as single or twins, I have twins and if I could do it over I think I would do a single, it would be half as much work when building the plumbing and doing the oil feeds and drains. Just my 2 cents
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 12-09-2009, 10:36 PM   #8
watahyahknow
watahyahknow's Avatar
thats a nicely made setup
let us know how it works and things you needed to change .
i'm realy trying to read up a lot on the small block turbo's now that my big block project has gone bust
it was too costly and was just too mush power anyways 1200 hp needs upgrading everything in the driveline wish makes the total costs for the setup about 3 times higher compared to going for 750-800 hp
the small block seems to be a better choice in terms of room around the engine and stuff available for it
i want to upgrade a 350 to forged internals bored and stroked to 383 (prolly scat and probe , vortec heads, a truckstyle low rpm torq cam a pro flow XT intake and megasquirt efi not sure yet on a single turbo or duals but it will be on the small side so it comes on boost fast and whont overtax the stock engineblock at higher rpms
scat now allso makes complete shortblocks using dart blocks wish would be a nice start too.
couple of nice tricks ive seen sofar is using a mecanical fuelpump blockoff plate to mount the returnline for the turbo on and using the stock oilpressure sender hole to take of the oil for the turbo using a T piece , the nice thing about this is that its undoable should you want to return the block into an natural asperated version
if anyone else has some good ideas about turboconversions i would like to learn about it
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 12-09-2009, 10:56 PM   #9
Wild83C10
Wild83C10's Avatar
check out this site out.
I will post details of my build when I get to it in the next month or so.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 12-11-2009, 11:26 PM   #10
63chevyll
gets board easy.......
63chevyll's Avatar
If you turn shortys upside down you will have to bend away from the valve covers
63chevyll is offline   Reply With Quote
Old 12-12-2009, 09:16 AM   #11
Wild83C10
Wild83C10's Avatar
Just an FYI but if you were to buy a set of stainless steel turbo headers they usually run at least $800 and a set of steel headers run at $600.
turbo=
Old 12-12-2009, 04:43 PM   #12
Alex1
Alex1's Avatar
Thumbs up Re: Turbo headers/manifolds?
That's about right. I spent about $700 (incl 2 SS V clamps) on material and about $425 to weld up my turbo headers. All 304ss.
Alex1 is offline   Reply With Quote
