11-01-2008, 10:00 PM | #1 |
do i have to much trani fluid in trani
when i put the truck in drive it takes right off and spins the tire then i try to stop it and it kills it, the engine is never running vey fast even when it takes off. wondering if i have to much transmission fluid in and i can't check it since i can't run the transmission to warm it. what is the easiest way to take some out.
11-01-2008, 10:16 PM | #2 |
SKINNY TIRES RULE!
Re: do i have to much trani fluid in trani
drain it, replace the filter and refill with the appropriate amount.
It sounds to me more like a carb problem though...
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-02-2008, 10:31 AM | #3 |
Old School, New Style
Never heard of such a thing being caused by to much fluid. Sounds like a broken torque converter maybe. This would happen with a 'lockup' torque converter if it wasn't unlocking.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
11-03-2008, 09:14 AM | #4 |
anyway to unlock it without taking it out.
11-08-2008, 08:38 AM | #5 |
if it is a lock up tranny, then it would have a couple of wires going to the tranny, unhook them, that will disable the lockup function....
11-08-2008, 09:42 AM | #6 |
67-72 parts collector,…
What exactly are you working on? What truck? What year? What transmission? 3 speed auto? Auto w/ overdrive? Got any pics of the engine?
11-08-2008, 11:22 AM | #7 |
72 gmc 350 v8 with 350 turbo Has low1 and low 2, also is 4wd
11-08-2008, 12:02 PM | #8 |
Sounds to me like your engine idle is set too high.
Start it, let it run for 20 minutes. Then while its in PARK check the tranny fluid level.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
