PITbut
Im at my wits end here with door alignment.
Im really at my end here. This door is goign to be the damn DEATH of me...
I can NOT get it to align. The top upper left corner touches and the upper right where it curves down is sitting about 3/4 of an inch to low. My questions are this. Can that door frame be bent? Can i remove the spot welds at the bottom right corner of the post and pull the post up a bit and reweld it??? ANY tips to getting the door to align would be appreciated.. here is another pic... Also, the hinges were pretty bad so i replaced them. Nice and firm now. ![]() |
Still livin the "dream" in '54
Re: Im at my wits end here with door alignment.
Just a thought... add a couple of washers under the upper door hinge where the door bolts too and try lifting the whole door a bit... You can also slide the upper part of the door out at the same time.
These things are tricky to align... I had to use a washer or two to get mine to align... also raising my hinges helped alot...even if it is a little bit. You might be suprised what raising or lowering the hinges can do to alignment... Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
///RELAXED ATMOSPHERE
Yes alot of times it takes cutting and welding to make doors and cabs line up. that looks to be your only alternative in this case.
Like a BOSS |
Couple of questions. Has the hinge on the top been rebuilt? If you lift on the rear of the door do you feel slack/loose? If yes to question 2 the hinge is your problem. The pins have only a nylon bushing to support them and these after 30+ years give up and cause all types of problems. Is the door GM or aftermarket? If aftermarket many of them do not fit the hole very well and require adjustments to the window frame to fit the hole correctly- i.e. removing spot welds and adjusting. Is the door original to the truck? Some doors just don't fit other trucks very well. Last one have the rockers been replaced? Were the door opening braced when the rockers were cut out? If not the opening could have shifted and caused the problems you are having. I hope that the problem is the hinge as it is a $6 fix and relatively easy.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
The Older Generation
It looks to me like the truck might have been wrecked at one time. With the wide door gap at the bottom of the wing window and the gap at the back top corner I don't think you will be able to adjust it out.... I would say that the top of the a pillar is pushed back. How does the other side look? LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-04-2008 at 11:06 PM. |
454 MAKES IT ROAR
Have you tried a different door? if you can strip and old door off a junker or something and have a look to see how it fits...as this might just be an out of shape door prob and not as big as a cab prob. If it's the same bad fit take the glass out of your door and cut and weld your door around the window frame to fit the opening rather than the other way round. Won't be to much of a change in shape to affect the glass and wing window going back in hopefully.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
blood type; Retumbo
looks factory correct to me. this is why my Dad always complained about GM's fit and finish.
the curved area gap is due to the drip rail being off. re-work the rial if you want ti to fit good. the gap at the bottom of the wing window area will take a bunch more work though. how does the cowl-door-A pillar-fender corner look? can you post some pics of that? |
That looks better than a lot I've seen.
1997 GMC Sierra Ext 1965 Mustang |
#9 | |||||
PITbut
its even better since i tweaked on it a bit.. Still doesnt fit right in the upper right corner and the lower left .... |
Didn't I read here, or was it listening to my dad who worked at the St. Paul Ford plant for 42 years, that doors were aligned at the assembly plant with a 2x4? You bent the door frame by closing it on a hunk of 2x4.
I'm glad mine aligned good enough because I'd be afraid of bending them. Now that I'm on the subject of using 2x4s on your doors, I watched in horror one day as my dad whacked the door glass track on to the window with a hunk of 2x4. He was over and I mentioned that I had a new track, a new piece of rubber to put between the track and the glass, and couldn't figure out how to put it all together. He took the glass, rubber, and track out on to the grass in the lawn, lined up the rubber and track, and whacked the $#!+ out of the bottom of the track to get it on the window.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I cut mine at the top where the A pillar meets the roof and took 1/4 inch out... I am running 1 piece windows so I did not have to worry about the vent window fitting back in properly...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
PITbut
My plan is to remove the spot welds at the rear of the window track and move it UP 1/4 of an inch. Reweld it in and if i dont like how it looks i will do what you said and take some out of the top of the a pillar area....
Just looking at it I think that the door will hit the cab in that front corner.... Looks tight now and if you raise the back that will move forward... unless you cut it where I cut mine to allow that gap to open up so just the top move up then reweld it.. Never the less... Good luck!
#14 | |
PITbut
#15 |
Built 4 Speed
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
#16 | |
Looks good at 20-ft .....
A lot of people call this "Rockansas." ![]() ![]() ![]() ![]() I have seen that very thing done in a glass shop on a carpet-covered wood workbench, tho. |
#17 |
![]() ![]() Join Date: Jul 2002
lyrikz
I can't see your photo from work, but sounds like what I had to do. Yes you are thinking correctly about the welds. I had to do the same thing on my passenger door (came from different truck). Check out my build thread...starts about Post #111 http://67-72chevytrucks.com/vboard/s...=221437&page=5
#18 | ||
PITbut
#19 | |
PITbut
#20 |
Now that I figured out the photos in here, yeah your door top looks like it got tweaked and I think C10addicts suggestion might be the best bet.
However before you cut, I think I might try placing a 2x4across the top of the door and whack it a few time to get that bow out, then release the loosen the welds on the rear of the door and see it you can get it to align better without the cut. If not, then do the adjustments with the cut suggested
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-05-2008 at 06:47 PM. |
#21 | |
PITbut
More pics to come soon... |
#22 |
The part that sucked the worst for me is both of my doors were brand new Goodmark doors! Out of the box and under the knife!
#23 | |
PITbut
I know that my top rail in the middle bows up... Im going to use the 2x4 method, beat on that middle section for a bit.. Then recheck the fitting... If that doesnt help, go with the right section first.. Hopefully i dont have to cut the apillar of the door.. that would suck. ahah... |
