Old 11-07-2008, 02:17 AM   #1
Moose67
Moose67's Avatar
Vacuum Source for Brake Booster
I am installing a power brake booster on my son's 67 2wd Chevy. It has the 250 6 cylinder, where is a good source of vacuum? When I got the truck the PO said it was a reman engine so I don't know the year. Thanks for your help.
Moose67 is offline   Reply With Quote
Old 11-07-2008, 02:19 AM   #2
hdflstf
hdflstf's Avatar
Re: Vacuum Source for Brake Booster
Intake manifold port that is right about dead center of your picture.
hdflstf is offline   Reply With Quote
Old 11-07-2008, 10:26 AM   #3
Luvlegs
Luvlegs's Avatar
yep - what hdflstf said - in your pic, it's right above the silver colored exhaust collar - yours even appears to already have the hose barn installed in it.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 11-07-2008, 11:09 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Hey Moose, what year booster are you using? And are you also installing the propertioning valve with it?
fyi: I installed pb on my all drum 68 many years ago (don't remember where I got it) but it made the brakes grabby. In other words, in a quick stop, the back brakes would lock up and scare the h-- out of everyone near me.
It may be because I didn't install a proportioning valve with it, but for now I'm back to manual brakes until I get the right parts.
68gmsee is offline   Reply With Quote
Old 11-07-2008, 01:17 PM   #5
Moose67
Moose67's Avatar
Sorry I left out some info. I have an ECE disc conversion and ordered the booster from them. It has the prop valve and the booster pictured below. I saw the offset breather in the FS section, but it will have a 350 in there before next summer. I am thinking about going with the open element air cleaner available from Summit or Jegs
luvlegs-- Hose barn? Which part is that?
Old 11-07-2008, 01:25 PM   #6
65ShortStep
I think it's this part.
65ShortStep is offline   Reply With Quote
Old 11-07-2008, 01:29 PM   #7
Moose67
Moose67's Avatar
I pulled that off and its a blind hole. Can I just drill it out or what?
Old 11-07-2008, 11:00 AM   #8
71 super
71 super's Avatar
you will have to have a different breather, the one you have will not work w/power brakes. i saw one on e bay yesterday, they have an off set that that moves the breather to the other side of the engine.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-07-2008, 08:53 PM   #9
factorystock
factorystock's Avatar
No, it is not that circled piece.That is just a stud the accelerator linkage swivel attaches to on car applications.There is another threaded port just about 2 inches away to the left. It would be directly behind that black round thing in photo.
factorystock is offline   Reply With Quote
