Rear engine crossmember
I know I have seen this covered somewhere but I can't find the tread. I have a '66 LWB that already had a sbc & th350 installed when I got it. I noticed that there is a very intrusive crossmember below where the trans meets the engine that from what I've read was for rear engine mounts for an I6. Did V8 trucks have this crossmember? Have you guys removed this crossmember? If so, is it just a matter of grinding the rivets off? If it doesn't need to be there, I want it gone.
Thanks! |
Hollister, CA.
![]() Join Date: Sep 2006
Re: Rear engine crossmember
I just removed mine last night.....it supported the stock 3-speed bellhousing an tranny.
About to post pics in my thread.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Why does it taste purple?
I did not know you could even get a auto tranny to clear that thing. I cut mine out while I was swapping from the 3spd to an auto
i cut mine out it was in the way when i installed a small block and a turbo 400.
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
Make it go away if you're keeping the automatic - mine had a 350/350 in place over that crossmember when I got it, but I had to cut it out to fit the big block; get a real automatic crossmember for under the tail of the trans. You'll have to figure out a plan for the e-brake cable connection also.
I bought a brand new cross member for less than 80 bucks I do believe
Thanks everyone! I'm going to have at it with the grinder and see if I can remove the crossmember. I'll take a look at your build thread for some removal tips chief.
yea i have that in my truck. it was the cross member for the four speed i pulled. im going with a auto but if i can fit a th350 in without taking it out ill do that incase i replace the four speed later.
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
