Old 11-10-2008, 11:13 AM   #1
pete29
steering doesn't work good on truck
I recently put a new steering box on my truck i then jacked the front of the truck off the ground put new ps fluid in and turn the wheel right to left several times, but when it is on the ground in park or moving slow you can't turn the wheels. Should you be able to turn the wheels when it is in park, if so any suggestions.
pete29 is offline   Reply With Quote
Old 11-10-2008, 12:38 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: steering doesn't work good on truck
Yes, you should be able to turn the wheels. Is the steering box for a 2wd or 4wd?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-10-2008, 12:56 PM   #3
pete29
Its a 4wheel drive box on a 4wd truck.
Old 11-10-2008, 01:15 PM   #4
bouncytruck
SKINNY TIRES RULE!
Did you use the stock steering arm? Could you have an air bubble in the lines?
bouncytruck 1972 K5
Old 11-10-2008, 02:04 PM   #5
pete29
Yes i did use the stock arm and i think it is probably because there is air in it. What is the best way to get it out.
Old 11-10-2008, 03:05 PM   #6
RED72blazer
urban fourwheelin
RED72blazer's Avatar
with the engine running move the steering wheel lock to lock....repeatedly.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 11-10-2008, 03:36 PM   #7
pete29
I jacked it up and did that several times, my cap on the pump isn't very tight, could this be the problem. Any way you can unhook the line with it running to get out the air. if so which one.
Old 11-10-2008, 03:49 PM   #8
hdflstf
hdflstf's Avatar
A new box will 'eat up' a bunch of fluid. If the lock to lock doesn't get it, drive it some, do some u-turns etc and check the fluid.
I assume you have the egine running when it's in park when you are trying to turn the wheels?
hdflstf is offline   Reply With Quote
Old 11-10-2008, 03:53 PM   #9
RED72blazer
urban fourwheelin
it can take awhile. how many is several times? 5 or 6? I'm talking like 50 times...I've had a lot of pumps take forever.....and don't unhook a line while it's running, you are asking for a big mess.
Old 11-11-2008, 07:10 AM   #10
vtblazer
vtblazer's Avatar
Not an initial concern, you can run it with the cap off/out if you wanted to watch the fluid levels.
Is the pump whining?
vtblazer is offline   Reply With Quote
