Old 11-10-2008, 01:47 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
12 bolt diff cover leaking
The other day i noticed that my differential cover on my 12 bolt rear was leaking. I had changed the fluid in it not too long ago and i heard here on the forums that most guys dont use a gasket and just use silicone (which i did). I took the cover off, cleaned the surfaces, applied a bead of silicone and new fluid. Today when i came out to my truck, it was leaking again. How thick is the bead of silicone suppesed to be? How long should i let it cure before i reinstall it? What do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-10-2008, 02:55 PM   #2
cdowns
cdowns's Avatar
Re: 12 bolt diff cover leaking
leaking rear covers is mostly due to overtightening of the bolts //they requirs 45INCH pounds of torque more causes the holes in the cover to dimple out causing leaks//i still believe in the original style gasket with a light coating of permatex avaition sealer
Old 11-10-2008, 03:03 PM   #3
Elephanthead
Use "the right stuff", it is appropriately named gasket in a can. It keeps what you want in and what you don't want in out.
Elephanthead is offline   Reply With Quote
Old 11-10-2008, 08:21 PM   #4
crm318
crm318's Avatar
I have a torque wrench i can use. Does that mean that its 3.75 foot pounds?
1972 Cheyenne
Old 11-10-2008, 08:26 PM   #5
cdowns
cdowns's Avatar
sorry i dont know the proper way to convert inch pounds to ftpounds//i've got different torque wrenches for bboth
Old 11-10-2008, 08:30 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Yes
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-10-2008, 08:39 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Very informative...I am having the exact same problem with my 12 bolt rear...I am SURE I have overtightened the bolts. I guess it is just like valve covers.
Old 11-10-2008, 08:50 PM   #8
zeeklu
When you clean the surfaces to be sealed ,I use brake clean or something similar so there's no oil residue. I also let the silicone dry over night or a couple of hours before adding oil. Chris
zeeklu is offline   Reply With Quote
Old 11-10-2008, 08:46 PM   #9
msgross
msgross's Avatar
I take the stock gaskets and put a thin coat of RTV on both sides...and spread it out with my fingers... wouldn't hurt to let it cure for a bit then refill it and go driving...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-10-2008, 10:32 PM   #10
crm318
crm318's Avatar
Yea, i think i tightened the hell out of them (well more than 3.75 foot pounds). ill inspect the surfaces and do it correctly tomorrow. Thanks guys.
1972 Cheyenne
