![]() Join Date: Apr 2005
Power steering question
I'm new to the 4 X 4 scene so bear with me,
![]() R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: Power steering question
Rob,
I don't know much about the 68 4x4's, but I would just swap the axle for one with disk brakes. I also think you need an adapter that goes on the frame for the power steering---someone correct me if I'm wrong. Welcome to the 4x4 world. john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 Last edited by jrdv; 11-12-2008 at 02:20 PM. |
#3 | |
the 68 front end should be a closed knuckle dana 44. your best bet would be to swap to a open knuckle front from a 71-72 because it'll have disks. also a corp 10 will fit but i don't know what is involved with that. as for the power steering you'll need an adapter plate as said above
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
#5 | |
Here is one that we use, as well as a complete kit...these are specific to the '60-'66, so I don't know for sure about the '67-'72, but hopefully this will get you headed in the right direction. www.carsteering.com is a good source for parts for a power steering conversion, as well as, you favorite local auto parts store (FLAPS).
I hope this information is helpful and good luck with your project. |
#7 | |
R/
check out the last couple of pages of my build thread... new axle is better, (any chevy solid axle will bolt right in, I ran a 1982 10bolt) if it has the flat frame like mine then you need the conversion bracket...
post #11 for you... http://67-72chevytrucks.com/vboard/s...33#post2916233
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 11-12-2008 at 09:52 PM. |
i think it is the same as the '60-'66
(yeah just saw your build msgross) it is the same, and Classic Parts is always $59.95 ![]() http://www.classicparts.com/1960-66-...info/76%2D979/
![]() ![]() Last edited by joe231; 11-12-2008 at 10:03 PM. |
all you have to do is find a good lil donor truck with everything on it..
my 68 has a corp 10 of an 87 burb as well as the whole powerstering set up... an everything works pretty well
![]() Last edited by dinotruck68; 11-14-2008 at 03:39 PM. |
not to be rude... but you would be crazy to actually swap a 10 bolt in right... i have broke 3 of those and pounded on 44's with 35" tires...
i know the brakes are nice and power steering setup but i wheel my ride and i hate 10 bolts... why not a 44 out of a later model.... i realize 60's are expensive... |
#12 | |
Rob, I have a link at home for a setup like that.. They were selling it for about $350-$400 for the complete kit at Carlisle... I'll PM that this weekend...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
sorry... was sharing some experience and believe i worded my reply as a question, as not to be rude...
this is the 4x4 section, not the comfort section, so i was trying to give a little advise based on 4x4'ing... cost's money to switch to these parts and i bet you could find a 44 almost just as easy... not tons better, but better... 10 bolts have very weak axles... even the aftermarket ones don't hold up very well.... if your just gonna drive your truck on road then i guess a 10 bolt will do great... JMHO msgross... your just jealous i have a 3/4 ton.... lol jk.... ![]() Last edited by Liz; 11-23-2008 at 10:59 AM. Reason: use the edit button instead of double posting |
