Old 11-12-2008, 06:06 PM   #1
thump16
thump16's Avatar
radiator for 350
I have a single core radiator that came installed on my truck. Is that going to be big enough to cool my truck? I have to 14 inch fans wired up but I'm probably going to reinstall my mech fan until I get a better fan relay.
thump16 is offline   Reply With Quote
Old 11-13-2008, 12:07 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: radiator for 350
personally i would only run a four core on my trucks... but im kinda a believer in overkill
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 11-13-2008, 12:27 AM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Wow defiantly seems to small I like the 4 core rads but have run 3 cores before but nothing smaller! I would think that your truck would want to overheat but I don't know.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-13-2008, 12:55 AM   #4
Pyrotechnic
Pyrotechnic's Avatar
3 core is stock and you should have at least that. If purchasing new, I think it's worth it going for a 4 core for the same price. You just need the larger rubber pads which are still available from GM and will cost about $20 for all 4.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-13-2008, 08:54 AM   #5
thump16
thump16's Avatar
So it's going to over heat with the single core rad? Advance auto showed the single core rad as a direct replacement for my truck. It was the lowest model they had.
Old 11-13-2008, 11:43 AM   #6
thump16
thump16's Avatar
I figured it out.
Old 11-14-2008, 12:49 AM   #7
Duro5341
Duro5341's Avatar
It all depends on what size core the truck came with stock.
If it's a 17" core, it will be a 3 core factory, if it's the HD 19" core the 350 came with a 2 core factory.
I recently upgraded mine from a 19" 2 core, to a 19" 4 core, all I had to do was get the proper rubbers in the rad support, and the 454 upper rad brace...and slightly trim the existing shroud to fit. It pushes the shoud about 1" into the fan, but the rear edges if the blade are at the end of the shoud for proper air pulling power.
Just my 2 cents
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
