Old 11-21-2008, 10:16 PM   #1
morgan71
69 k20 spring?
Okay 4x4 guru's I need some help. I bought a 67GMC a while back that to my knowledge has been set on a 69K20 frame. I identified this by the numbers stamped on the frame next to the powersteering box. It also has a 205 and Sm465. The springs have got me puzzled though. It has two leaves in the rear that measure 56" by 3 inches wide the fronts have three leaves that are 3 inches wide also. Is this a 69 setup? I assume someone has removed some rear leaves. I have some rear leaves out of a 80's model one ton that are the same length but only 2 1/2 inches wide. Can I make these work. I have seen on here somewhere about using these springs but can't remember where.
Any help would be great.
morgan71 is offline   Reply With Quote
Old 11-22-2008, 08:34 AM   #2
Mudder
Mudder's Avatar
Re: 69 k20 spring?
They should be the same width.
Mudder is offline   Reply With Quote
