11-22-2008, 01:21 PM | #1 |
my '71 LWB project - carb'd 6.0L gen III etc
figured I should start one of these. Been 3 years since I brought the truck home...$500 for a roller w/o engine or trans. Bed sides were good, frame good, 12 bolt rear and one fender. Scrapped the rest pretty much. I can't find the pics right now of the truck when I towed it home.
Picked up a cab in TN off a board member, it was shot in the lowers and cab mounts...but the windshield channel and upper areas were decent. So I got a crash course in cab fixin' LOL. Frame was stripped down and coated with Eastwood rust encapsulator.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 11-23-2008 at 10:46 PM. |
11-22-2008, 01:24 PM | #2 |
Re: my '71 LWB project - carb'd 6.0L gen III etc
general cab fixin pics.....
I did the driver side w/ sawzall and cutoff wheels....had enough and bought a plasma cutter. The other side went much smoother and then the bed too. Working in my small 30x30 garage w/ plasma and a 110V Lincoln welder.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
11-22-2008, 01:27 PM | #3 |
more cab fixin and windshield had 2 bad spots at the seam when I stripped it down.
11-22-2008, 01:29 PM | #4 |
rear end build....had a guy shorten the housing 1" and weld on 9" ford ends from Moser...stuffed it with an Eaton diff, 3.42 gears, Moser axles
truck will see some 1/4 mile action with drag radials or slicks...so I wanted the C clips gone.
11-22-2008, 01:32 PM | #5 |
fast forward to this summer / fall....pics of the cab welding done...epoxy primer on everything.
11-22-2008, 01:34 PM | #6 |
applied the 2004 GM quiksilver metallic with a cheap gun for the inside cab, firewall, and jambs.
test fitting the seats I'd like to use...2004 GTO buckets. comfy but tall back. Not sure yet if these will stay or something shorter.
11-22-2008, 01:45 PM | #7 |
Plan for the truck is Silver all over, with black accents..
Planning to keep the lower black trim and go with 18" black center wheel of some type. 30" tires to fill the wheel wells up. Engine is a 2001 6.0L LQ4 core...+030 and stuffed with 10.5:1 forged pistons from Diamond, Z06 cam out of a 2004 vette, with 317 casting heads milled slightly and my port work (nothing major). Dual plane performer RPM intake, 750 vacuum secondary holley, MSD 6010 box. 150hp plate nitrous shot. Shooting for a 400rwhp package on motor, and 500+ on spray....might need more cam to get there we'll see. Headers from a 98-02 Fbody, TH400 long tail trans and a one piece drive shaft.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 11-22-2008 at 01:48 PM. |
11-22-2008, 01:45 PM | #8 |
Tot Roddin'
What a great looking project!
Best of luck!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-24-2008, 11:39 PM | #9 |
72BlckButy: thank you sir
Not much to report...I got windshield in and intake showed up in the mail. Waiting on the rest of the motor to finish machine work..won't be long!
11-24-2008, 11:46 PM | #10 |
Moderator
Nice project. I love to see the carbed gen III's. Where'd you get the intake and msd 6010 and what did they set you back if you don't mind?
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-24-2008, 11:47 PM | #11 |
that is gonna be one sweet looking truck, love the motor combo you are goin with
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
11-25-2008, 09:17 AM | #12 |
Leevon, thanks. The MSD6010 I picked up off LS1tech.com basically new in box but opened for $260 shipped. They don't pop up often.
The intake I was going to buy at Summit, but were on back order. I checked at Advance Auto and got it there. Friend of mine works there and Nov. employees get 30% discount...so it cam out around $260 delivered. I was surprised. nuke1 - thanks
11-27-2008, 01:17 PM | #13 |
PROJECT 7DEUCE
Nice work so far cant wait to see her done..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-27-2008, 02:23 PM | #14 |
Formerly- 1972SuperCheyenne
Lookin' great man, good luck with the build.
11-27-2008, 05:27 PM | #15 |
Truck and auto performance nut
Nice! That's what's planned for mine as well, a carb'd LS motor. I'm hoping to build a 427 off a LSX block but will use a LQ4 or LQ9 and build a 408 if funds are tight when I get to that point. Besides what all went on my "shop truck"...I just have an empty frame right now.
Do you plan on relocating the coils? Mast has a nice setup that puts them behind the valve covers, for that old school look.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-28-2008, 10:06 AM | #16 |
68GMCCustom
yes I probably will relocate the coil packs....like to use the cast valve covers from GM performance with the "chevrolet" script on them. Those covers don't have provision for mounting coils. I was in the air about the 408 as well...but the 4" cranks are still pretty steep for my budget on this one. In a few years when there's more of them on the market used I may pick one up. If the economy really tanks maybe people will start selling their LSx blocks cheap LOL.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 11-28-2008 at 10:08 AM. |
11-28-2008, 03:06 PM | #17 |
I have a radical idea!
Is there an easy way to change a Gen III engine over to single coil with a MSD or similiar ignition box?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-28-2008, 03:07 PM | #18 |
Awesome truck BTW! The silver looks great!
11-28-2008, 04:05 PM | #19 | |
I believe so...but it requires using GM's front mount dizzy option.
11-28-2008, 07:10 PM | #20 |
keep up the good work.
1991 1500 longbed: my daily driver 1937 chevy 2dr sedan. dads project |
11-28-2008, 07:20 PM | #21 |
watching this one... hopefully I can get to see this in action around town...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-29-2008, 07:34 PM | #22 |
Looking really good really like the seats
11-30-2008, 11:48 PM | #23 |
thanks for the comments guys.
67 C30... The MSD 6010 box is a standalone unit that will fire the stock coil packs.. It's a little over $300. The front cover shown uses an adapter to the front of the cam, and a Ford distributor. The cover and adapter alone are like $450. In my opinion the best option is the 6010 box and the stock coils.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 11-30-2008 at 11:48 PM. |
04-10-2009, 10:25 AM | #24 |
been way too long for an update....I'm lazy, it was cold this winter...blah blah. Last month I been getting it going again....
Ported a set of 317 heads, lightly...just a clean up really. LH8 oil pan from a Hummer, worked out real nicely. Engine is 10.8:1 with Diamond +030 pistons. Z06 cam from a 2002 covette
04-10-2009, 10:29 AM | #25 |
Trans is a th400 out of a mid 80's blazer...rebuilt with goodies. 10" Midwest convertor 3200 stall....nitrous compatible
for mounting I stumbled across a set of frame stands w/ mounts in my dad's garage..believe these are 73-87 type mounts.
