ok, new here. i recently picked up a 72 c10 from a friend, it runs and drives great, but 2wds are not my thing. so naturally a prerunner is the direction its goin. the problem is the very little info i can find. ive read the few threads on here bout it, but most of those lean towards either a small lift(2-3") or goin to the fabtech kit, which finding one of those would probly take a loooong time. ive put dinos 66 in my favorites
Re: 72 c10 prerunner ideas...
i'd find a 4x4 frame and mount your 72 atop it
or get larger coils throw in a block or add a leaf out rear try in 4x4 section also
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
Do you want a Prerunner or just a lifted 2WD? Because in my opinion they are very different.
If you want a kit, check out Blitzkrieg Motorsports. They make a crazy high travel kit for the front end, but requires a straight axle. I ran across some pictures of a 72 Blazer frame where they built an I-Beam front suspension, and saved them. This may be more work than you want, but it sure is cool. ![]() ![]() ![]() ![]() ![]() ![]()
If you can find it cheaper, I can fix it! |
wow, that blazer is amazing...
i guess i should have been more specific. i want a longtravel front suspension, somwhat cheap, that is usuable as my daily driver. i know im not gonna get nothing that is incredible, all im lookin for is great handling offroad, capable of small air time without serious damage, and 4-6" of lift to clear 33-35" tires. basically, somthin like the fabtech kit dino's 66 has, without the 4" lift spindles. the truck will be daily driven, but i want to be able to play with it without hurtin it. my fab skills are ok, but i have a friends whos fab skills are awesome. the only thing is im tryin to do this as cheap as possible, and with as little down time to the truck as i can. thats what brings me to believe custom control arms, built off the originals is the ticket. if i can get ahold of some other stock control arms we can build customs without the truck bein down. im thinkin if we take the measurements for camber/caster angles we can just build some thatll give bout 4" of drop in the balljoint/spring pad area, kinda mimic'in the fabtech arms, only 4" lift not 6", and 2" wider for more trac and travel. anybody have any input on this?? im very new to all the camber and caster and angles, built many strait axle 4x4s but compared to this thier a cakewalk... |
I built something similar to what you are talking about for a newer Chevy. I built arms that widened the front track width a total of 6 inches (3" per side) with Uniballs in the lower arm, and a factory balljoint on the top. I didn't build any lift into the arms, although I'm sure it could be done. What I did was use a Bilstein coilover to lift the suspension, and adjust the balljoint angles to compensate for the new angles of the control arms. And I sleeved the tie rod adjuster to lengthen it. I unfortunately can't share my pictures here, but you can browse the RaceDezert forums to find some similar setups on newer stock vehicles such as F150s and the NBS Chevy trucks, and the new Tundras and Tacomas.
Happy to be here
![]() Join Date: Mar 2000
Welcome to the forum Cap'n. It sounds like you have some cool plans. Since you are trying to do this on a budget and keep your driver drivable, I suggest you buy a spare frame. This will allow you to build it as time and money permits and swap it over when it's done.
Twisted Minis- Thanks for sharing the pics, and offering your experienced insight.
chevy only
![]() Join Date: Sep 2006
hey cap'n , are you looking for the fabtech arms? and my 66 is for sale or trade i post it this week
CHEVY ONLY... Nothin Else ! Last edited by Dinos63; 11-25-2008 at 12:39 AM. |
I dont care how you do it, i just want to see that heavy ___ thing fly thru the air... see u at the dunes!!
chevy only
twisted your work is unreal
CHEVY ONLY... Nothin Else ! |
Too many toys,not enough money
Hey Twisted Minis, good to see you over here on this board! I've admired your stuff on hotrodders for a while. Good stuff!
I'm no fabricator by means but I have owned fords with the I-beams and stock they were like riding a pogo stick. To me the i-beam set up seems like a ton of fab is needed, and heavy, I think I'd go with control arms. Id also think that if you did take an awkward landing, chances are one side would be taco'd with the control arms, where as the I-beam it could take the whole kit and kabootle out. Basically, repair would be easier. If you are a sand dunner, I'd want as much ground clearance in the front of that thing as possible. Any thing that digs into the sand would endo that thing faster than you could say "boy howdy, hold my beer and watch this".IMO Last edited by MT71c-10; 11-28-2008 at 12:57 PM. |
![]() Join Date: Nov 2006
I have to agree with twisted minis. I-beam is the way to go for 2wheel drive. Unless you have a ton of cash
(regardless if you are doing youre own fab work or not)! Pre-runners are no joke. Most of the ones you see on the streets are not real "pre-runners". Jumping a truck puts alot of stress on the suspension/steering/frame and the heavier youre truck the more stress. I can go on and on about this but basically there is not an easy answer for what you are asking. Here is a good forum for what you are asking race-dezert I'm sure youre question has already been asked once or twice over there. Good luck and post pics when you start youre build ![]() |
OK OK I'll play.
I am working on a 67 stepside. I call it a prerunner. I'm on the Race-Desert and Pre-Runner and Fab forums, and in true form, it is a 2wd lifted truck, only. The 'real Pre-Runners' are insane, and so is the money. So it's going to be a lifted 2wd, driver fun machine. 88-98 front lifted spindles I found a Moog spring catalog I'm digging thru for springs, something soft would be nice. 88-98 front 6 lug discs I have a set of lower tube arms, they might end up on egay... I plan on setting up everything going for a drive and then maybe finding someone to build me custom longer upper and lower control arms. If I need more something No sence in getting in to deep, this is going to be a driver, not a frame off custom 24 inches of travel, morgage the house, trying to keep up with the fast boys. I've seen the true 'Pre-Runners' and basically they are a Trophy Truck with four seats (usually) and a full interior. Cubic dollars. I looked at one at SEMA and snapped a few shots and scratched my head and said DAMM. Now back to a thin wallet, not living in fabrication heaven, and one of the very few raising a 67 2wd Chevy. Nobody to ask advice of, and doing something very few people are interested in. Does that make me a 'rebel' or an idiot. Mick |
Happy to be here
Welcome to the forum Forced-racing. Thanks for sharing with us.
#15 |
I would say launch it And get pics and upgrade what breaks. Thats if it has a cage, which I can't tll if it does, appears not to , but it could be what I'm thinking is the dash.
But nice find.
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
#16 | |
No cage yet, just runs and need work. Major rust issue, it will need a cab eventually. |
#17 |
OK, I have a progress photo.
I hope this works... Last edited by MickMc; 01-15-2010 at 02:02 PM. |
#18 |
#19 |
Todd
35 Pro-Comps on 8 wide Outlaw II. Suspension...I've posted up how to do it in other posts, PM me if you can't find them (I'm not trying to be a dik but I've posted it several times, other people started it and I completed it, BUT it's not done and I haven't had it to the alignment shop yet so technically I can't say it works, but it is 6 lug disc with Hydroboost... |
#20 |
At the body shop.
A-arms tied together and 1ton x-member struts
" That didnt make it any newer " " Dont antique the equipment " |
#21 |
Cool stuff!
