Old 11-28-2002, 01:05 AM   #1
Low69CST
Motor and electrical problem fixed
I got my carb. rebuilt which fixed my motor problems. My motor sound great. Rough idle, deep throaty sound and gets wild quick with just a little throttle. I got thinking about why my ignition kept shutting off when I turned it to the "On" position. Cuz I also noticed my add-on tach wasn't working. Most people said I wired the painless system wrong, but it turned out i forgot to put the ground strap back on the cab, so nothing would work. To test it i used a pair of jumper cables to ground my cab and my switch instantly started workin. Not only am I excited about how mean my motor sounds, but my wiring really works!
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 11-28-2002, 01:22 AM   #2
littlebubba
Check your pm
Have you checked your "pm", I left a message for you.
littlebubba is offline   Reply With Quote
Old 11-28-2002, 01:05 PM   #3
Low69CST
do these pics work?
