Old 11-22-2008, 11:08 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Where to buy QUALITY battery cables
The cables on my big block are hokey and I want to replace them soon.
Where can I buy good quality large cables for top terminal batteries ?
I'd make them myself with welding cable if necessary if I could find the proper ends and tools needed.
I mean quality stuff, not parts store prepackaged junk.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-22-2008, 11:14 PM   #2
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: Where to buy QUALITY battery cables
I always just go to AOC and have them cut wire and crimp ends on it for me, they have all the stuff there.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 11-22-2008, 11:15 PM   #3
71swb4x4
71swb4x4's Avatar
I buy mine from a local car/tractor electronics shop. They make the cables. I either give them the exact length, or bring an old cable in. Since you are a welder, I assume you may work with farmers. If so, ask them where to get the cables mase.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-22-2008, 11:17 PM   #4
chipflyer
chipflyer's Avatar
Try your local John Deere Ag dealer, years ago when I worked in one we had a really nice crimper and made our own cables with quality ends and good cable. Might even check with other shops/dealerships, I am sure someone around can still makes them.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 11-22-2008, 11:44 PM   #5
lilred67
lilred67's Avatar
hey tx, try woodruff's automotive in weatherford, they built custom battery cables.. rusty
lilred67 is offline   Reply With Quote
Old 11-23-2008, 06:55 AM   #6
Tx Firefighter
Where are they in town ?
Old 11-23-2008, 09:49 AM   #7
lilred67
lilred67's Avatar
on mineral wells highway, across from city hall. one block west of the court house on the right..
haven't seen you around in a while, glad to see your still truckin'
Old 11-23-2008, 11:03 AM   #8
8mpg
8mpg's Avatar
Your local Napa Autoparts should make custom cables. My buddy is a manager and makes mine. Great quality with soldered ends, not crimped
8mpg is offline   Reply With Quote
Old 11-23-2008, 11:04 AM   #9
Wrenchbender Ret
Carquest has some good quality cables if you get a counterman to look in the catalog for you. They have any gauge you want when lengths in 3-5 in increments.
Wrenchbender Ret is offline   Reply With Quote
Old 11-23-2008, 11:56 AM   #10
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
TX I always get my 1, or 2 ga. cables and ends at my local Orilleys, then solder everything together.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 11-23-2008, 11:59 AM   #11
Painter D
Painter D's Avatar
Some car audio shops sell quality battery cables.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-23-2008, 01:53 PM   #12
Senator350
Senator350's Avatar
I always get the BRAIDED wire from the parts store (zero or one gauge) and get my terminals from Jegs.com. I have really grown to like the threaded ring terminals they sell
RN U OVR
Senator350 is offline   Reply With Quote
Old 11-23-2008, 05:07 PM   #13
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
I always make mine as soldered assemblies.
Just made one for my '72. Got all the stuff at Napa-- the terminal, the lug on the starter end, the heavy cable, and the shrink wrap (the good kind with the glue in it).
Clamp the terminal in a vise with the barrel up. Heat it up, feed solder into it until it's about 3/4ths full, stick your stripped cable in and hold it still for about 30 seconds. Then shrink wrap. Easy. You can also get special solder "pellets" to just drop into the barrel and heat until molten before sticking your cable in, but they're not necessary.
I put some split loom on this one.
Lugnut64052 is offline   Reply With Quote
Old 11-23-2008, 05:13 PM   #14
8mpg
8mpg's Avatar
Just for next time... Napa sells these little pellets that are solder/flux combo made for battery terminals. They are different sizes for different gauges of wire.
Old 11-23-2008, 06:32 PM   #15
tcb-1
Nothing to see here.....
tcb-1's Avatar
second that. Phoenix Gold makes some extremely nice cables..... not cheap though.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
