11-25-2008, 02:11 AM | #1 |
Frame for 66 SWB 4X4
I'm looking to stock up for my next project. I am planning on buying a 66 cab and I want to build a SWB 4x4. I've spent some time researching and I've got a question about frames. Since I don't have a frame, what should I look for? How close (in length) is a 73-87 SWB frame to the length that would be needed to build a regular-sized 66 SWB 4x4. I'm a ways off, but having a plan on what I need to buy is always a good idea. Thanks, Jeremy.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
11-25-2008, 09:16 AM | #2 |
Re: Frame for 66 SWB 4X4
I have a 76 short 4x4 frame and my 61 4x4. I'll check the differance in wheelbase for you.
11-25-2008, 10:24 AM | #3 |
Thanks. I'm in no hurry, but just wanting to know what would be best. I'm sure someone has done it. I'd just like to find out which requires the least cutting.
11-29-2008, 02:44 AM | #4 |
60-66 Nut
If you were to use a '67-'72 frame, you would have less work to do if any for cab and body mounts. If you use a '73-'87 frame, you'll have to build most all new frame brackets for the cab and body mounts.
