11-28-2008, 11:07 AM | #1 |
Drop blocks?
Does any one know where i can buy lowering drop blocks from? i found a pair on ebay but for $100 i was told that they should cost under $50 for about a 2" drop
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
11-28-2008, 11:18 AM | #2 |
Watch out for your cornhole !
Re: Drop blocks?
I make my own out of 2 inch square tubing. I did an FAQ article on the whole process if you care to search for it.
11-28-2008, 11:20 AM | #3 |
Re: Drop blocks?
Here:
25 bucks and a lot of satisfaction from doing it yourself... http://www.67-72chevytrucks.com/vboa...ghlight=blocks
11-28-2008, 11:25 AM | #4 |
PROJECT 7DEUCE
Re: Drop blocks?
This is the method I used worked great..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-28-2008, 11:48 AM | #5 |
Re: Drop blocks?
Wow thats nice looks easy enough now i got to try and find the time and tools to do it. wouldnt want to make a pair and ill buy them off you would ya?
11-28-2008, 11:58 AM | #6 |
Re: Drop blocks?
this is what i did..
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
11-28-2008, 12:08 PM | #7 |
67-72 parts collector,…
Re: Drop blocks?
Looks like the block was 7" long. Does anyone know the "center to center" length of the u-bolt holes? Also what size holes to drill? (I think I drilled mine 7/8",... but I cant remember.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-28-2008 at 12:49 PM. |
11-28-2008, 12:17 PM | #8 |
Re: Drop blocks?
i made mine last week... the center to center of the hole is 4.25 inches.. and i drilled a 7/8 hole
11-28-2008, 12:40 PM | #9 |
Under Construction
Re: Drop blocks?
I dont know the measurements or the size to drill the holes. but if you have the original shock mounts you could get the measurement off those.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 11-28-2008 at 12:49 PM. |
11-28-2008, 12:49 PM | #10 |
Re: Drop blocks?
Thanks for the quick replies.
11-28-2008, 01:56 PM | #11 |
Under Construction
Re: Drop blocks?
let me know if you dont have any shock mounts available to measure. PM me and i can go look through the parts in the garage(have some somewhere) and get you some measurements.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
