Old 11-28-2008, 10:22 PM   #1
theyammieguy
accepting donations
theyammieguy's Avatar
Stiffen up the rear
I have lowering springs on the rear but I haul motorcycles and pull low boy trailers very regulary. Is there a stiffer lowering spring I can install?
Here's the spring. I think it says 6101-4, but I took the picture this morning and don't remember for sure.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 11-29-2008, 02:41 AM   #2
Shane
Shane's Avatar
Re: Stiffen up the rear
the spring says McGaughey's Classic ... why not call them.
Shane is offline   Reply With Quote
Old 11-29-2008, 01:00 PM   #3
theyammieguy
accepting donations
Good point, huh?
David Crockett
Old 11-29-2008, 11:01 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
You would be better off putting an airbag back there. You can set the ride height depending on your load.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-29-2008, 09:26 PM   #5
ERASER5
ERASER5's Avatar
I'll have to agree. To get it all, you will need bags. Get leveling switches, and your golden. No matter the load, you will keep your stance. Well, with in reason anyway.
I have leaf springs, so my plan is to use air overload bags to get the results I want.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-30-2008, 12:59 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Forum member Scoti has a simple set up on the rear of his truck. He has bags with seperate fill lines and schrader valves to fill them. He uses it for a tow rig, parts hauler, etc. His set up has served him well for several years.
Articles-
"Refining Sierra"
Old 11-30-2008, 09:30 AM   #7
bigsnookmaster
bigsnookmaster's Avatar
Ive used those same bags for years and they work great,but I had to modify the top spring mount because the airline exits out the top of the bag.Air-lift makes them and Jeg's sells them for about 80 bucks or so.They fit inside the coil and keep the springs from compressing so much.You can air them up and haul a ton,or lower the pressure and have a comfortable ride..Best bang for the buck I have ever installed in my truck.Good luck.
bigsnookmaster is offline   Reply With Quote
Old 11-30-2008, 07:41 PM   #8
ENHANCED AIR RIDE
I just looked at Air Lifts application guide and they show no direct fitment for the Air Lift 1000 kits. However you could just do a regular rear air setup and use manual paddle valves in the cab to control like a load control setup, or use schraeders for real cheap kit. I have sold several like this for these reasons.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 11-30-2008, 09:42 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by ENHANCED AIR RIDE View Post
..... However you could just do a regular rear air setup and use manual paddle valves in the cab to control like a load control setup, or use schraeders for real cheap kit. I have sold several like this for these reasons.
That's actually what I was talking about. Although you can probably find a helper bag that might work, I don't suggest it.
Not that it won't work, but I have found that the stiffness of the bag inside the spring prevents the vehicle from taking full advantage of the lowered spring. You might loose an inch or more of drop.
Articles-
"Refining Sierra"
Old 11-30-2008, 08:27 PM   #10
theyammieguy
accepting donations
I was thinking about it, and I could use a leveling valve like on 18 wheelers. They are cheap and easliy modded to fit anything.
David Crockett
Old 11-30-2008, 09:45 PM   #11
theyammieguy
accepting donations
Wonder if I would be better off just doing a 4 corner bag?
David Crockett
Old 11-30-2008, 10:08 PM   #12
Mrwlliam
Sounds Like the BUG has hit you... !!!!
Mrwlliam is offline   Reply With Quote
Old 11-30-2008, 10:19 PM   #13
scotts62
One day...
scotts62's Avatar
Hate it when that happens
Scott
93 crew cab build
Project 62
Old 11-30-2008, 10:19 PM   #14
theyammieguy
accepting donations
It sucks man. I'm trying to finish the build on my chopper and now I go get this truck. Lol
So much to do with so little money and time. Don't even know where to start. I'd like to get the outside looking sweet but that's the expensive part and I will need this truck to drive on rainy days. Im to the point where I know I will need at least one cab support, new floorpan, new firewall, and new rockers.
The problem is trying to figure out how to do all the work on the weekends and still have the truck ready to roll incase I can't ride the bike.
David Crockett
Old 11-30-2008, 10:23 PM   #15
Mrwlliam
There are worse problems..hahaha.. i know what you mean.. i just picked up my own project truck.
Old 11-30-2008, 10:26 PM   #16
theyammieguy
accepting donations
It's not to bad of a truck, only rust that I'm concerned about is behind the dash to the left. Not sure what the panel is called. It above the kick panel
David Crockett
