Old 11-29-2008, 01:37 PM   #1
Huck
Huck's Avatar
6 cyl truck tach cluster
Kind of rare--an original truck tach cluster for a 6 cylinder truck---originally had air pressure too. I had to replace the bezel and the lense. This tach cluster has the rear metal for a air pressure or vac gauge so you can upgrade this too which is kind of nice. 8 cyl tach dash clusters are pretty common and available in aftermarket too but an original 6 cylinder~~~~~yep, kind of hard to find. Probably only available on larger trucks so here is your opportunity 6 banger guys~~~. $350. shipped US lower 48 mainland~~. Huck
Huck is offline   Reply With Quote
Old 11-29-2008, 04:10 PM   #2
1969stepside
1969stepside's Avatar
Re: 6 cyl truck tach cluster
that looks like a 8cyl tach to me but i could be wrong
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 11-29-2008, 05:13 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Would like to be first in line.
Question, does it come with the harness and can you tell me if it came out of a truck with a striaght 6 versus the V6?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-29-2008, 08:13 PM   #4
Huck
Huck's Avatar
See factory stamp on rear~~
Old 11-29-2008, 08:22 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
There is no difference in a 6 cyl or 8 cyl tach from the front. If it only goes to 4000 rpms it is a mechanical drive diesel tach which looks similar. The stamp on back tells you what it is for.
I am also unaware if there is a difference between V-6 or I-6 tachs?
Huck, nice set-up. TTT for ya.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-29-2008, 08:07 PM   #6
Huck
Huck's Avatar
CPNE--does not have the harness with it but i will make one up for you if you need it. It came out of a farm truck--don't know if it was a straight 6 or V6---should not make any difference. And yes, it is an original 6 cyl tach and you can see the factory stamping on the rear cover of the tach. Huck
Old 11-29-2008, 08:49 PM   #7
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Eric is correct, the 6 and 8 cyl. look the same and the 4k diesel tachs are cable driven and hook up just like a speedometer does.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 11-29-2008, 09:33 PM   #8
LooseCannon
Put me second after CPNE.
LooseCannon is offline   Reply With Quote
Old 11-29-2008, 10:15 PM   #9
larry may
How does a tachometer know if the signal is from a V8 or a 6 cylinder. Just curious!
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 11-29-2008, 10:42 PM   #10
Huck
Huck's Avatar
A tachometer doesn't know what it is hooked up to--you have to tell it! It will respond by indicating how many revolutions per minute the signal is sending. For 4,6,8 cylinder engines, it will simple be designed to divide the number of signals by the number of cylinders and indicate via a magnetic pulse to a indicator which will correspond to the gauge marking. What sometimes causes issues is the length of the pulse wave such as an HEI verses a points ignition system. These old tachs are not very accurate compared to current technology which is solid state verses electro-mechanical. Huck
Old 11-29-2008, 11:52 PM   #11
1969stepside
i have seen 6 banger tachs with a white line on the gauge face and the needle looked diffrent that is why i thought that it was diffrent what tach did i see
Members i Have met
Earl Slick68
Old 11-29-2008, 11:54 PM   #12
larry may
Smile Re: 6 cyl truck tach cluster
hoorah. Well done. and thank You Huck.
Larry
Old 11-30-2008, 09:12 AM   #13
Huck
Huck's Avatar
CPNE===you're #1
LooseCannon===you're #2
will send CPNE a PM with 24 hour response required--Huck
Old 11-30-2008, 10:34 AM   #14
CPNE
Resident Curmudgeon
CPNE's Avatar
PM received. I'll confirm my intentions by this evening. Thanks
Old 11-30-2008, 09:03 PM   #15
CPNE
Resident Curmudgeon
CPNE's Avatar
Sold, Pending Paypal info from Huck, PM sent
Old 12-01-2008, 09:32 AM   #16
Huck
Huck's Avatar
SOLD and thank you all for your timely information re the 6-8cyl tach confusion. Perhaps in the future some will refer to this as a information page on the differences. Huck
Old 12-01-2008, 12:02 PM   #17
Livrat
Member #1049
Livrat's Avatar
Just thought I would post an FYI...
The part number for the V8 tach is: 6468226,
And for the 6cyl: 6468321.
Livrat is offline   Reply With Quote
Old 12-01-2008, 12:34 PM   #18
Mt Man Chad
Mt Man Chad's Avatar
Dam how did I miss that one!
Douh....
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 12-01-2008, 03:57 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That's what I was thinking Mt Man Chad...
Nice score CPNE!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
