I need some help guys....
Ok so here is my truck i have a 1983 swb and i want to get some rims but i dont know whats the biggest rim size i can get without them rubbing and i also want to lower it but i dont know whats the lowest i can go without having to do any major motifications. i would really appreciate yalls help grownups usually know best lol
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: I need some help guys....
Lowering it is a major modification, so I don't know what else you mean.
Generally 4/6 is a good all around drop, that you can get away with for a driver. Wheel size depends on the amount of drop. Are you talking big as in diameter or width? 17's up to 20/22" combo's look good as to width, you can fit 8 in there, but, again how much drop...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#3 | |
These where the wheels i was looking at
That is a good question,what is the biggest tire size we can put on our trucks without rubbage or mods.
The general is always in charge ![]() You guys did this to me!!!!!!!!!!!!!!!!!!!! |
yea turbotank i would really like to know that also because whenever that time comes around i dont want to have to spend anymore than i have to
It depends on the amount of drop, size of the rim and the size of the tire, but in general, 28" tall and about 10" wide is all that will fit in front without cutting the inner fender.
Are you sure???? cause according to my specs,my stock 235/75/15 tires are 28.87 inches in diameter.And those are only 15s!!! Now,that is not taking into account width of tire,but I would think that more diameter then 28 can get under there with no problem,just by visual,I would say at least 30.But I am far from an expert!!!!
Not with a 4" drop and stock inner fenders.
Yeah,I would agree with that,not with a 4" drop,but stock I would think you could squeeze some pretty big tires in there.
LpStreetKing, wanted to know about drop and tire size.
Stock you can fit up to a 32" tall tire.
The One And Only !!!
That truck looks sharp with the rally wheels, I'd do a 4/6 drop and call it a day.
Only because I just spent 2 hrs polishing wheels, They look great when clean but takes a lot of work to keep um clean.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
yea restorob i was also thinking about that i was just thinking about keeping the setup i have now just drop the truck and paint the wheels i have now the same color as the truck i think it would look pretty badass like that also
yea kaptkaos i was thinking either 4/6 or 5/7 drop with either 20's or 22's i didnt want to go any bigger than that with some low profile tires
#15 |
Dually Pride
over on the 4x4 side they have a tire size guide for lifted trucks, maybe someone should make a lowered truck one
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
#16 |
Yea that would be a pretty good idea but i wouldnt know how to do that
