Old 12-05-2008, 03:47 PM   #1
terrellautosports
New Member
terrellautosports's Avatar
coilover shocks
any of you guys that are running these i need your help. i need to know what spring rate you are running, what length spring, what shock compression and stroke? and if anyone knows where i can get a good set as cheap as possible. or if any of you have a set for sale.
any help will be appreciated.
i am getting everything lined up to use coilovers on an IRS for my wifes truck.
it is a corvette rear end.
thanks in advance.
1968 SWB Project. Soon to Start Build Thread
terrellautosports is offline   Reply With Quote
Old 12-05-2008, 10:05 PM   #2
Wild83C10
Wild83C10's Avatar
Re: coilover shocks
There are ways to calculate the correct spring rate to use. It's based on the weight on each wheel and the distance from the pivot point of the control arm. I think QA1 has the formula on their website. I would also call the company you are going to buy them from.
I saw a pretty good deal for adjustable QA1s on racingjunk. I think QA1s are the best for the money. The varishock is probably the best but those will set you back more then $700 a pair.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
