PROJECT 7DEUCE
![]() Join Date: Dec 2002
Thoughts on ride height???
Im needing to set-up my watts link but need to figure out my ride height. So guys whats the best way of doing this I am still needing my drop spindles do I need to wait or can I set-it up now? Right now I am running 15 wheels and tires but am gonna step up to 20''s do I need to take that into consideration? Any helpful info or insight would be great..
set-up I have now consists of front stock 72 spindles ( soon to be ordering 2 1/2 drop spindles) strong arms firestone bags 1 1/2 drop crossmember rear 2'' blocks bags are on order but will mount to the trailing arm flipped center crossmember
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Thoughts on ride height???
So you plan on bagging the back? I prefer to set them up at half travel. So if you get 8 inches of lift, set it up at 4 inches.
If you can find it cheaper, I can fix it! |
A guy with a truck
You should set the rear suspension where it will be at ride height. If you are using a 7" diameter bag(RE7,2600) installed bag height will be ~6". Stick a temporary spacer(block of wood, etc.) at your desired installed spring height on top of the trailing arms and rest the frame on them. Build your Watt's at this height. Tire diameter will not affect where your suspension is at ride height-only how far your frame is off the ground.
While your air suspension is adjustable, to function properly, it will need to operate within the manufacturers installed parameters. So, basically, you can set it up as though it were static. Clear as mud? Side note- What Watt's set-up are you running? - Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
PROJECT 7DEUCE
The re7's are the bags I ordered as far as the watts link it is part speedway part home brew from looking at others on the board. Do I not need to pay any attention to fron camber toe in toe out etc etc?
A guy with a truck
Yes you do, but it should not affect your rear suspension height. For mock-up purposes, you could set your front suspension up at current installed height, then deflate 'til you're 2.5" lower. That way, everything is as it will be at ride height. There is quite a bit of adjustment for camber at the upper a-arm mount, so you should be OK there.
I agree with Twited Minis....that is basically the way we will set them up too.
