12-06-2008, 04:56 PM | #1 |
t-case questons
Ok guy's, i'm about to put the tranny and t-case back into the blazer but I wanted to put some gear oil into the t-case. Where do i fill it? Can i use the breather opening? Any help wld be appreciated. Thanks, Mario.
12-06-2008, 09:36 PM | #2 |
Re: t-case questons
I guess nobody out there knows, I filled it through the pto plate.
12-07-2008, 02:55 AM | #3 |
Re: t-case questons
It should have a plug on the side to fill it. Just like the rear end.. Fill with 80 -90 gear lube till it comes out the hole (with it on fairly level ground) then put the plug back in.
12-07-2008, 03:07 AM | #4 |
Re: t-case questons
Thanks Old Man Jimmy, The t-case was pretty wel crusted over with dirt and grime. Didn't even see the plug. I ended filling it up through the pto plate. I really appreciate the feedback. Thanks, Mario
12-07-2008, 09:20 AM | #5 |
Re: t-case questions
Their should be 2 holes the one in the bottom is for draining it and the one above it is for filling it.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
12-07-2008, 09:49 AM | #6 |
Correct. Since you filled it thru the PTO plate, find the regular fill plug to make sure you have the right amount of fluid in the case.
