Old 12-07-2008, 02:20 AM   #1
str8sixblazer
My Heater Is Not Blowin Hot????????
the blower works great,i got a 180 brand new thermostat, the hoses are hooked up, and the heater core aint leaking? any info is appreciated thanks
68 swb 2tone flat orange and black
72 2wd blazer six banger (project)
str8sixblazer is offline   Reply With Quote
Old 12-07-2008, 09:50 AM   #2
Huck
Huck's Avatar
Re: My Heater Is Not Blowin Hot????????
Couple of issues to check---is the hose to the heater core getting hot indicating flow? 2nd--the heater control flapper needs to open to allow air to pass through the heater and into the cab. Depending on if the truck is an AC or Non-AC---trace the cables to see if they are hooked up or broken---start to disassemble the in cab heater ducts to find the air flow blockage. It can and often is a Mickey Mouse House nest in the plastic heater housing which can be a PITA to clean out but must be done if it's blocking air flow.
Huck is offline   Reply With Quote
Old 12-07-2008, 11:23 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Also, could be the heater control valve. The lever is in the heat mode, but the valve is not opening allowing hot water to run through the heater core.
68gmsee is offline   Reply With Quote
Old 12-07-2008, 01:25 PM   #4
str8sixblazer
thanks for all the help. but where would the hearter control valve be?
Old 12-07-2008, 02:42 PM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Also you could have a bunch of leaves or something in your cowl & heater box blocking air flow
And you may have a heater core that is corroded up inside, but check all the other stuff before you replace the core
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-07-2008, 03:26 PM   #6
caminokid
Chevy nut
caminokid's Avatar
Or could be like me....pinched hose to the heater core.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-07-2008, 03:45 PM   #7
Camper Power
Camper Power's Avatar
try checking your coolant level, if it gets too low the heater won't work. this happened to me once
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
