Old 12-12-2008, 07:23 PM   #1
57larry
Qjet won't kick down
when it was warm, my 84 C10 with a 350 and Q jet carb ran fine. Now it's cold and it idles high and I can't get it to kick down. it has power going to the electric choke. what should I check? thanks
57larry is offline   Reply With Quote
Old 12-12-2008, 09:28 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Qjet won't kick down
Larry,
I would test the choke with a multimeter to make sure it has a closed circuit, It could be blown. Also check your high idle cam and linkage on the carb for any binding/stiffness.
Good Luck
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-12-2008, 09:57 PM   #3
57larry
ok, thanks, I'll check the ground
Old 12-12-2008, 11:15 PM   #4
Restrorob
Restrorob's Avatar
It's not really a 'ground' your checking, Un-plug the wire and set your meter on ohm's scale. Touch one test lead to the wire connector and the other to any part of the carb, You should get a closed circuit reading if not the heater windings are blown.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 12-13-2008, 11:43 AM   #5
57larry
are the choke windings able to be replaced?
Old 12-13-2008, 04:41 PM   #6
Restrorob
Restrorob's Avatar
No, Just replace the choke assembly then adjust while the engine is cold.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 12-13-2008, 05:40 PM   #7
84 400
Sb 400 club
84 400's Avatar
I also have a Q- jet question. On my 77 with a 350 if i tap the pedal it kicks down but when I place it back into park after driving it idles high again. Any ideas what could be causing this.
thanks
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-13-2008, 06:44 PM   #8
73chevyman
73chevyman's Avatar
its a QJET thats why i got a eldy
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 12-13-2008, 08:43 PM   #9
84 400
Sb 400 club
84 400's Avatar
I have an eddy on my 84 and love it. easy to tune and runs dead on all the time. But I am not switching to an eddy on my 77. If anything I will rebuild th e Q jet 25.00 for a rebuild kit and a half hours worth of work..
Anyone have ideas on mine kicking down but idling back up when placed in park?
1985 C10 LWB Sold
Old 12-13-2008, 10:20 PM   #10
Restrorob
Restrorob's Avatar
Could be a couple things, When it idles high in park after driving can you tap the gas and have it idle back down ?
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 12-14-2008, 05:26 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
OK, More than likely your fast idle cam is sticking on the first cam step. One reason could be that your choke pull-off is not operating properly. That cost's about 15 bucks and is a pretty important component that most people overlook during a rebuild. What style choke do you have? Electric, divorced?
Old 12-14-2008, 09:24 PM   #12
84 400
Sb 400 club
84 400's Avatar
yes when placed back into park it idles high but will kick down with a tap of the gas. I am not sure what style choke it is . I will have to take a closer look on friday and get back to you.
1985 C10 LWB Sold
Old 12-15-2008, 07:42 AM   #13
Albatrossian
Georgia Boy
Albatrossian's Avatar
More than likely it's the pull off.. I've seen that happen alot.. and a sticking linkage. WD40 it. QJets are awesome carbs.. I have a 780cfm version that I had professionally built. Crisp, clean response that's like a lightswitch. I get good mileage and equal or better performance than any Edelbrock or Holley.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
