I am a Referee of life.
Radiator cleaning
not the inside but the outside.It has some of the green corrosion on it.I want to paint it before installing it and wondered if anyone had a way to get it good and clean.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
The Older Generation
Re: Radiator cleaning
You might try some vinegar and a toothbrush on it. Just put some in a spray bottle, spray it on and let it set for a few minutes. I don't know about that type of corrosion but it works on computer motherboards that have corrosion on them.... ![]() LockDoc
Blaze-Air
In the olden days we would pour cola on battery terminals to clean corrosion, it may work for your application. I need to do the same thing to my rad.
i'd try spraying the outside with "lime-away" then carefully with hose or powerwasher rince prior to paint(thin coats)
67lwb
![]() Join Date: Sep 2007
tobasco sauce and a wire brush works to take corrosion off of brass valves should work for that.
Active Member
![]() Join Date: Jun 2002
Don't know about the rest of you but everytime I had green corrosion it indicated a leak. Might be so small it evaporates so you never see the leak but it will get worse. Take it to a radiator shop and have them check it out. Might save problems later on.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
it's a leak that's already started. pay now or pay later. your call.
Trueman Last edited by 463; 12-14-2008 at 01:54 PM. |
