![]() Join Date: Dec 2007
Aeroquip socketless hose
Anyone using this set up for high pressure fuel? I have some left over from a different project used as low pressure oil line. Company specs this at 250 PSI. Socketless makes me a little nervous.
Re: Aeroquip socketless hose
u would have to tell us exactly which hose you are using. Some of it may not have a lining that is suitable for gasoline.
Probably the best thing to do is to go into the catalog or check the online catalog and see if the hose is suited for gas. |
Its AQP hose and its listed for gasoline as well.
On a side note, I've actually been through Toppenish. I had an old friend that lived in Sunnyside...... Ever heard of the Farming Game?
Yes I have. I haven't bought one yet though.
If they say it is good to go with gas I don't see why you couldn't use it. Yep, it's getting harder to hide from anyone around here. |
Thanks for the replies. Much appreciated.
Jay |
Mean Green
I have -8 Aqip for a supply and a return line. My pump puts out over 30 psi till it hit reg. So you should be fine. i believe all Aqip is oil/gas compatible.
Thanks Hoosier smoker. My mind is a little more at ease. It just wierd pushing a hose onto a barbed fitting without a clamp/socket and stepping back and thinking, yeah, thats good for 100 psi gas!
![]() Jay Last edited by 5150.4.67; 12-13-2008 at 01:33 AM. |
Mean Green
I know, odd if the dang fuel injected guys running Boost can get away with it we are way in the green. I guess that's why its called Aeroquip. its Aero space knowledge.
Agreed, its good stuff.
Jay |
socketless is fine for high pressure EFI. I have used it many times with EFI. Socketless is some tough stuff. Lots of diesel guy use it all the time.
Thanks! That's what I wanted to hear.
Jay |
Have not heard of it as "socketless". We, in the forklift business and I'm sure there's others, use what's called "push-loc" hose. Sounds like the same stuff, just different name? Works real good for low pressure (0-250 psi). Just my $.02.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
same stuff... The teeth on the barb fittings really have a bite to them.
