Old 12-14-2008, 01:57 AM   #1
bamaboy165
bamaboy165's Avatar
2 kenwwod 12's shallow mount
hey guys im new to this forum but i got a 1970 chevy c-10 and i got 2 kenwood shallow mount 12's and i was wonderin where would be the best spot to install these and what box?? i still have the gas ank in the cab.
bamaboy165 is offline   Reply With Quote
Old 12-14-2008, 02:01 AM   #2
chevychase
chevychase's Avatar
Re: 2 kenwwod 12's shallow mount
Welcome to the board! I've seen them mounted under the seats but don't know what is involved. You can try using the search button, I'm sure you'll find plenty of ideas and info here.
chevychase is offline   Reply With Quote
Old 12-14-2008, 02:07 AM   #3
bamaboy165
bamaboy165's Avatar
thanks man ill try that
Old 12-14-2008, 02:17 AM   #4
AK72K10
AK72K10's Avatar
With 12's you may want to consider moving the gas tank out of the cab, that would clear up some room for you, then you could mount the amp(s) under the seat(s).
AK
_____________________________
1972 K10 Custom Deluxe 350/350
2008 Suburban LTZ Custom Deluxe
1972 F100 302
"Why Build It If You Can't Drive It?"
AK72K10 is offline   Reply With Quote
Old 12-14-2008, 03:15 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
I don't think you'll get anything bigger than a 10 under the seats. I've got a little RE8 8" thats going under mine with a little alpine mono amp and a second amp for the fronts.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 12-14-2008, 09:52 AM   #6
bamaboy165
bamaboy165's Avatar
ok yall thanks so much but how hard is it to remove the gas tank? and how much would it run me. im just thinkin about puttin it inside my bed how hard would this be. give me ideas,pointers etc. thanks.
Old 12-14-2008, 01:25 PM   #7
AK72K10
AK72K10's Avatar
I don't want to steer you wrong Bama so I am pointing you in the direction of Texasbigblock, he recently posted a thread where he installed a gas tank back near the rear bumper, turned out looking great and had a flip down license plate for tank access. Also, Cameeks posted some info in the same thread that might be helpful. Hope this helps.
AK
______________________________
2008 Suburban LTZ White Diamond
1972 F100 302
Old 12-14-2008, 01:32 PM   #8
bamaboy165
bamaboy165's Avatar
thanks man i will check them out
Old 12-14-2008, 01:37 PM   #9
NYC-10
screamin eagle
NYC-10's Avatar
Last year I installed 2 pioneer slims under the seat,I made my own box facing the subs up.I also fit 2 amps where the jack used to be.
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 12-14-2008, 03:16 PM   #10
Lippyp
English Chevy Owner
Lippyp's Avatar
This is whats going in mine plus the four channel.
This is a picture from another board members truck, those are two 8's iirc so 12'2s are going to be very tight. I'm going with the same size box only one sub but two amps.
Phil
'67 C10 long fleet.
Old 12-14-2008, 03:30 PM   #11
chevychase
chevychase's Avatar
Found this for under the seat:
http://67-72chevytrucks.com/vboard/s...subwoofer+seat
Old 12-14-2008, 06:21 PM   #12
bamaboy165
bamaboy165's Avatar
thank yall guys i think im just gonna raise my seat and pop the twelves under the seats. thanks guys
Old 12-14-2008, 08:51 PM   #13
killacheyenne
killacheyenne's Avatar
tell me how that turned out BAMA and show me some pics of it when your finished
72 cheyenne super
83 chevy...4x4...454
killacheyenne is offline   Reply With Quote
Old 12-14-2008, 09:28 PM   #14
chevychase
chevychase's Avatar
Do you know how much port volume the speakers need? If not, I'm sure you can google your speaker part#'s and find out. That's kind of important to get the right sound. I think the shallow mounts don't require much so you may be OK.
Old 12-15-2008, 04:12 PM   #15
bamaboy165
bamaboy165's Avatar
would it be better to put them in one long box or two single boxes under the seat?
Old 12-15-2008, 04:23 PM   #16
70short
Remove the tank out of the cab install a Blaser tank behind the axle. Very easy and not that expensive. Then put the speaker box behind the seat and the amps under the seat. Here is what I did 3-tens sealed box sounds awesome!!!!!!!!! Something about having a gas tank inside the cab that bothers me JMO.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-15-2008, 06:37 PM   #17
bamaboy165
bamaboy165's Avatar
preciate the input man but ive already decided to put them under the seat lol so what would be better one long box or two seperate boxes?
Old 12-15-2008, 07:56 PM   #18
NYC-10
screamin eagle
NYC-10's Avatar
I put one long box and divided it in the middle.I removed the cable to adjust the seat so it would fit.Also if you take out the jack 2 subs fit in there nicely
SCREAMIN EAGLE
Old 12-16-2008, 12:36 AM   #19
bamaboy165
bamaboy165's Avatar
sweet are yours behind the seat or under?
Old 12-16-2008, 09:04 AM   #20
NYC-10
screamin eagle
NYC-10's Avatar
under
SCREAMIN EAGLE
Old 12-16-2008, 04:49 PM   #21
bamaboy165
bamaboy165's Avatar
awesome does puttin them under the seat take away any of the bass?
Old 12-16-2008, 05:26 PM   #22
killacheyenne
nyc-10 put some pics up of your subs
72 cheyenne super
Old 12-16-2008, 06:07 PM   #23
crites_72
crites_72's Avatar
I would like to see how they fit in the jack spot also.
DJ
crites_72 is offline   Reply With Quote
Old 12-16-2008, 07:00 PM   #24
NYC-10
screamin eagle
NYC-10's Avatar
your asking me to remove my bench seat-maybe tomorrow if the weather is not to bad
SCREAMIN EAGLE
