12-01-2002, 10:19 PM | #1 |
Just an Old Mr Goodwrench
Remanufactured 350 High Performance Engine
I'm getting ready to put this on Ebay, but thought I'd give the board members first shot. I'm starting the Ebay auction at $1500 with a "buy it now" price of $2500 - board members can email offers to wlee@socket.net
Here's the specs: High Performance 350 Chevrolet Complete engine Here’s your dream engine, ready to drop in & go! This is a 1974 Small Block Chevrolet 350 C.I.D., 4 bolt main, cast #3970010, stamp #VO415TJB that’s been professionally re-manufactured. Cylinders bored .020 Clevite .010 main bearings and .020 rod bearings. New flat top .020 pistons, original rods tested & reused. 64cc double hump 327 Feulie heads, cast #3917291, 1.94 intakes and 1.5 exhaust valves Triple ground with new brass guides, Z-28 springs and new valves magnafluxed & milled giving a 10.3 compression ratio. Fel-Pro 1003 Blue high performance head gaskets Clevite 229-1713 Hydraulic lash performance camshaft with an advertised duration of 306 intake and exhaust, duration at .050, lift is 222, Valve lift is .447, cam lift is .298, lobe spread is 114 New Johnson HT 817R lifters Black Moly Push Rods Black Moly roller rockers 1.5 intake / 1.6 exhaust Black moly push rod guide plates. Melling M-55A high velocity Z-28 Oil pump Melling Distributor drive shaft. Cloyes double roller timing chain and gears New Holley 650 CFM electric choke Quadrajet GM Polished aluminum manifold, GM ID#458520. New HEI ignition custom tailored for maximum performance. GM performance polished aluminum valve covers, GM part #141-108 with the Chevrolet logo stamped in red on top. AC Delco stainless steel bolts MotorChrome 350 High Performance air cleaner with blue flags Chrome timing cover Cal Auto Transpeed Chrome harmonic balancer Chrome triple pulley Chrome oil pan and dip stick. Engine is painted with High-temp ceramic cast coat iron, which compliments the chrome parts nicely. Fuel pump and water pump are NOT included. This is a professionally built engine and carries a 12 month limited parts only warranty. Parts are warranted against defects in materials and workmanship. This warranty specifically excludes racing use, any competition, or marine use, and parts that fail as a result of alteration. Should any part prove to be defective, that part, and only that part may be warranted at my discretion. The buyer assumes full responsibility for the full cost of the repair, service, damage and/or loss to property. It is the buyer’s responsibility to check for any state and Federal laws concerning engine replacement, modification, and emissions regulations.
1969 CST 20 Longhorn 1970 CST 20 Fleetside 1991 Jaguar Sovereign 1992 Mazda Miata |
12-01-2002, 10:20 PM | #2 |
side shot
