My 65 Build
Figured I would quit lurking and add my truck/build. My name is Nick and I reside in Phoenix.
Bought my truck from my grandfather, who bought it brand new. It is a LWB 1/2 ton 283 3 on the tree. Have done disk brakes, 5 lug swap, gas tank out of a 55 chevy car under the bed. HEI 4 barrell, dual flowmasters, turbo 400 swap when 3 speed broke 2nd gear. Its a clean truck and a good plat form to start my cruiser project with. Sorry the first handful of pictures are scans. Didn't have digital cameras 15 years ago. The first pic was taken at G Pa's house circa early 70's I beleive. The rest of the pics are before and after I got the wheels for it. Prime 5 star aluminums 15x8.5 in the rear and 15x7 in the front. |
Wheelin' and Dealin'
Re: My 65 Build
looks likea good solid truck
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
1 thing at a time is progress.
Re: My 65 Build
Welcome aboard from North Georgia. Nice truck and a great history of it.
Alan
Philippians 2:14-16 |
Re: My 65 Build
So around my birthday this year, when the 110 degree days went to the way side, I decided I was tired of seeing my truck sit(it has been sitting for 3 years) and decided it was time to go to work on it. Not sure of all the pictures I have of the dismantalling process. However I pulled the complete front clip and suspension, cross members out of it. I have had a 355 sitting in the garage waiting to go in it. Out with the 283, and begin the cleaning/degreasing and painting process. When I pulled the front clip in late sept I wasn't sure to which degree I was going to go, however it consumed me.
Re: My 65 Build
So once I got everything out of the way and could see what i had to work with. I started to clean things up. The frame and firewall (removing that factory undercoater is a real m f r).
Re: My 65 Build
So I started cleaning up the firewall and decided it would look super sweet if it was smoothed out. I have to admit alot of peoples trucks on here have given me ideas and motivation.
Re: My 65 Build
A few more of the older pictures of it. Then I will bring it up to date.
The first picture is me using it as a work truck. ![]() The second is with my lake hot rod. ![]() |
Re: My 65 Build
wow man, looks good!
very nice work! welcome!
Hollister, CA.
![]() Join Date: Sep 2006
Re: My 65 Build
X2 !!
![]() Welcome from California
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Its Deja Vu time again
Re: My 65 Build
Man seeing this stuff really gives me hope I can do mine.
![]() Thats just awesome and thank you for that comment that you've not done that stuff before because it lets people like myself know that heck if he can do it so can I. ![]() |
#11 | |
Re: My 65 Build
The welding was all done with a gasless flux core, harbor freight style welder. Not the welder of choice, however I borrowed it from a friend, and it worked. My dad has a nice mig and tig at his house, but he is an hour a way, no practical way of getting his stuff here or my truck there. The filler work is what took the most amount of time. One tool that saved a load of time with the filler that I aquired, is a pneumatic bar sander. I have a home remodeling and repair company, and I do alot of paint spraying. Though its not exactly the same, some of the basic techniques are the same. 50/50 over lap, keeping the tip perpendicular to the surface... such on and so forth. I learned alot from the different threads on this board. I bought a semi cheap paint spray gun from the Home Depot. Read on how to set it up, messed with it, painting some non useable parts. Its not perfect, but I'm building a cruiser not a trailer queen. I will gladly give you any tips I learned along the way, just ask. ![]() I'm excited to get it back together. I am putting power steering and brakes on it this time, it was all manual before. Its not the most conventional way of restoring a truck, however I don't have a garage to work on it in, and I wanted to be able to drive it while the weather is still cool in the spring, so I opted to just do the front section first. Next I will clean up and spray some paint in the interior. I have an extra set of bed sides, so I can start on the body work on those before removing the bed and doing the rear end. I am not doing any major frame modifications, just a static drop for now. Maybe air ride down the road. Any how enough of my rambling for now. ![]() ![]() |
Re: My 65 Build
Very nice...
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
Re: My 65 Build
I like what you did to the firewall. I'm going try to clean mine up as good as you did, thanks for the pictures. What's a pneumatic bar sander? This is where I am now.
#14 | |
Re: My 65 Build
Here is a picture of a bar sander. Hooks up to an air compressor, and it moves back and forth. Very helpful in getting the panels flat. Luckily my dad had one, so I just borrowed it. I cut the small raised panel where the blower motor goes through completely out and patched in a piece of 16 ga sheet metal. Once I get the motor put back in. I will then figure out where to run my wires through. I plan on relocating the main wire harness, to where it comes out just under the fender well, and running the wires in a donduit of some sort under the fender well. |
#15 | |
Re: My 65 Build
Alan
#16 |
Tot Roddin'
Re: My 65 Build
Nice looking build, keep up the good work!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#17 |
Re: My 65 Build
Made some headway today, while the rain took a bit of a break. Dropped the fenderwells and core support off at the blaster to be media blasted. Sorry no pics of that.
Started stabbing some parts back in. Crossmember, rad. support, core support mounts, power steering box. got the column test fitted (sorry no pics of that) |
#18 |
Re: My 65 Build
Picked up the grade 8 hardware at the local ace. I like that place, they leave it up to the consumer to fill in the prices of the loose hardware. $43 worth of grade 8 bolts, nuts, and washers to put this stuff back in.
#19 |
Resistance is Futile
Re: My 65 Build
Looking good YZ. It was nice to have the sun out for awhile today.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#20 |
Re: My 65 Build
So I have been trying to work on the truck for at least an hour a night. I got my fenderwells and core support back from the blaster yesterday. Today when I got home, I welded up the holes on one fenderwell and gave it a quick coat of filler.
![]() I have posted some other pictures. The other fender well and the core support. I will be working on those in the new few days, not going to do a whole lot with the core support, however I will weld and use some filler on the other fender well. You can see a few coil springs in the pics. I one set is the stock front springs. The other ones are some jeep TJ front coil springs I scored. Anyone used these springs do they work with a small block? I also scored the rears, all for free, so I am not complaining. ![]() |
#21 |
Re: My 65 Build
Here is a few pics of the control arms and the spindles, that I am going to take to the atv shop my sister works at, and use their blast cabinet to clean up. I am going to be ordering the rest of the parts to put my motor together, hopefully on monday. My plan is, to shoot the fenderwells, core support, and the rest of the front suspension over the christmas break.
#22 |
Re: My 65 Build
Well it has been a while since I have updated. Or even been on the site. However I have made a little bit of progress. Got a little side tracked there for a month or so. My twisted knee was feeling good enough to get back on the dirt bike, so I had to ride a little bit.
Here are some of the engine build pics. 1st is my engine gaurd dog. 2nd parts accumulation. 3rd crank in. 4th cam degree. 5th rotating assembly in. |
#23 |
Re: My 65 Build
Some more engine build.
1st windage tray and oil pump. 2nd Oil system primed up. 3rd arp fasteners and fuel pump block off. 4th Intake bolted up. |
#24 |
Re: My 65 Build
Will update more this weekend. I painted the control arms yesterday. Will be priming the fenderwells and core support this weekend. Might get the front end started put back together. Ordered my torque converter so that when that comes in, the engine is ready to swing back in. Keep on keepin on. Hope to drive to the cruise on central in early April.
#25 |
Re: My 65 Build
Some more updates.
![]() ![]() Upper and lower control arms painted. Fender well prepped. Electrical conduit welded underside of driver fenderwell, for wiring harness. |
