12-14-2008, 11:27 PM | #1 |
Moderator
Restored my center console
I have finished the restoration of my center console. I painted it with GM dark blue 523. Thanks to Mel for the ashtray, and another board member from awhile back for the emblem. To my knowledge, to be factory correct, it should be medium blue. I just think it looks better because it matches the paint inside my cab (and the outside of my truck) perfectly. What do y'all think?
12-14-2008, 11:30 PM | #2 |
Re: Restored my center console
It looks real good Scott, nice Job!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
12-14-2008, 11:33 PM | #3 |
That thing looks like its new ! You did a great job
72 C20 Longbed 05 1500 Z71 |
12-14-2008, 11:32 PM | #4 |
Resident of Here
Looks real good!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-14-2008, 11:35 PM | #5 |
Old member
Looks fine to me. If it matches the truck paint then I think you need to repaint the whole truck!!!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-14-2008, 11:48 PM | #6 |
Looks NICE. Great work
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
12-14-2008, 11:48 PM | #7 |
Looks great, the blue ones seem to be a hard color to match to the factory.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
12-14-2008, 11:58 PM | #8 |
Moderator
Thanks for all the kind words! My door panels will be next. I am thinking of doing all the interior pieces in dark blue.
12-15-2008, 12:11 AM | #9 |
that console looks awesome, are you sure you restored it and you didnt buy a new one
if the door pannels turn out that nice you will have a sweet interior
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
12-15-2008, 03:42 AM | #10 |
It looks great!!!!! I need to work on my interior. How did you prepared it and what type of paint (vinyl paint, body paint) did you use.
[B]72 Cheyenne SWB |
12-15-2008, 12:35 PM | #11 |
Moderator
Thanks! I cleaned all parts with a nylon brush and simple green. Sanded it by hand very lightly, with 1200 grit sandpaper. Primered it with vinyl paint primer. Painted it with Plasti-Kote dark blue, code 413. It is an exact match to GM dark blue, code 523. It matches my factory dark blue exterior paint, and therefore the paint inside the cab. I do not believe it is correct as far as being an original color for interior pieces (door panels, visors, headliner, dash pad) I think only Medium blue was available for those pieces. Somebody please correct me if I am wrong on this?? I like the dark blue I used because it looks like it SHOULD be original. It is actually darker than the pics show....the flash makes it look lighter.
12-15-2008, 01:02 PM | #12 | |
My console:
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" Last edited by 1972CheyenneSuper; 12-15-2008 at 01:04 PM. |
12-15-2008, 04:47 AM | #13 |
Always on the hunt...
Hey Scott, no problem on the ashtray and glad to help. The console looks great, just one small thing and I am only mentioning it because I know that you are a stickler for originality. The color of the bowtie on the console lid should also be blue on your truck, the yellow colored one's were used on the later bucket/console models. Mel
12-15-2008, 12:18 PM | #14 | |
Moderator
12-15-2008, 08:41 AM | #15 |
Under Construction
looking good.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-15-2008, 09:49 AM | #16 |
Tot Roddin'
Nice work, that thing turned out perfect.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-15-2008, 12:25 PM | #17 |
Looks great! I think you did the right thing matching the dash/doors and the outside vs. the medium blue.
12-15-2008, 12:38 PM | #18 |
Moderator
Thank you! The door panels actually "blend" in with the door now. The med blue made it 2-tone and kind of stick out. I noticed in the factory med blue trucks that the door panels blended in with the door, and I liked that better.
12-15-2008, 02:32 PM | #19 |
Moderator
Thanks for the compliment. I do not have my buckets recovered yet...but they still have their original covers on them, with a few rips. I will take pics of them late tonite when I get home and post them here. That is the only thing I am afraid I won't be able to match to the headliner, visors, dash. I do not want to dye them as I am sure it will not stay as the seat sees a lot of contact! I know I had limited luck with the arm rests, the dye started coming off after a while. They still look ok, as my truck is a daily driver anyways. I am pretty sure that the headliner, etc that you order will be in the correct medium blue.
