Old 12-18-2008, 09:36 AM   #1
CDA 455
MidlifeCrisisUnderWay
CDA 455's Avatar
Exclamation Brand New Aluminum Radiator
It has never been installed; just taken out of box for inspection. Still have all packing/shipping material.
Radiator is specifically for '67-'72 Chevy Blazer and trucks (OEM replacement).
$195 plus the ride.
Located in Boise, ID
I have Paypal.
DIY4X
1972 CST Blazer <---sold
CDA 455 is offline   Reply With Quote
Old 12-18-2008, 11:08 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Brand New Aluminum Radiator
Who makes it? Is it a 4 core radiator? Does it mount with the factory brackets?
R/
Hart_Rod is offline   Reply With Quote
Old 12-18-2008, 12:30 PM   #3
CDA 455
CDA 455's Avatar
R/
Classic Radiators.
They're stock replacement fit.
From the eBay auction where I bought it:
NEW, ALL ALUMINUM 1967-1972
BLAZER & JIMMY HEAVY DUTY RADIATOR.
THE CORE IS A MODERN STYLE HIGH DENSITY 2 ROW CORE WITH AROUND 2000 MORE FINS THAN THE ORIGINAL RADIATOR. THIS WILL IMPROVE COOLING AND REPLACE YOUR 2,3 OR 4 ROW COPPER RADIATOR.
THIS IS HOW RACING RADIATORS ARE MADE TODAY.
The eBay page.
DIY4X
Old 12-18-2008, 04:12 PM   #4
454_72_4X4
454_72_4X4's Avatar
How wide are the core tubes?
I think most aluminum radiators are 1 in tubes, but some are wider, (and some narrower I'm sure).
My Griffen has 1-1/4 in tubes.
I'll do some measuring and see if I could use my Griffen in my Sonoma. If so I'd be interested in yours.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-19-2008, 06:55 AM   #5
CDA 455
CDA 455's Avatar
Back to the top.
DIY4X
Old 12-20-2008, 01:10 AM   #6
coopminvik
Can you tell me how this thing mounts,it doesn't look like stock mounts will work.Also, what size hoses does it take?
Jim
coopminvik is offline   Reply With Quote
Old 12-20-2008, 12:38 PM   #7
NWD02
CDA maybe this will help. I think I bought the same one from ebay. The top factory mounts work but it could look better. Here's a few pictures of mine mounted. I'm going to replace the top mounts as soon as the rest of the truck is together.
NWD02 is offline   Reply With Quote
Old 12-20-2008, 02:14 PM   #8
CDA 455
CDA 455's Avatar
Thanks for the pics !!
DIY4X
Old 02-10-2009, 01:35 PM   #9
CDA 455
CDA 455's Avatar
$195 plus the ride.
I have Paypal.
BTT
Price is OBO
DIY4X
Old 02-10-2009, 02:33 PM   #10
Hart_Rod
Hart_Rod's Avatar
What is the extra hole for? The one with the black cap on the right side.
Old 02-10-2009, 02:49 PM   #11
CDA 455
CDA 455's Avatar
Tranny cooler line.
DIY4X
Old 02-10-2009, 03:04 PM   #12
Hart_Rod
Hart_Rod's Avatar
Tranny cooler line.
OK, I'm confused. There's 2 gold holes (tranny??) and one black one (??)......
Old 02-10-2009, 03:08 PM   #13
CDA 455
CDA 455's Avatar
Yeah know, I am too now !!
DIY4X
Old 02-10-2009, 03:20 PM   #14
454_72_4X4
454_72_4X4's Avatar
I'd think it'd be the return from the heater core but it looks awful small.
Any dimensions on this thing? (H,W, core size)
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-11-2009, 02:43 PM   #15
CDA 455
CDA 455's Avatar
Ttt
DIY4X
Old 02-11-2009, 03:02 PM   #16
Hart_Rod
Hart_Rod's Avatar
CDA 455, did you verify this?
R
Old 02-11-2009, 05:01 PM   #17
NWD02
It's not the heater return it's for a sensor. Mine came with it. Not something you have to use.
Old 02-11-2009, 05:48 PM   #18
Hart_Rod
Hart_Rod's Avatar
I would like to use it for the steam port on an LS engine, but I want to make sure it actually goes into the water jacket of the radiator and not into the transmission cooler.
Old 02-11-2009, 06:03 PM   #19
jorgensensc
jorgensensc's Avatar
I bet it can be used for that hart-Rod. The only concern is that it would actually flow water through the steam tube. If I remember, doesn't the steam tube have to come in to the radiator above the water line and release into the system. If it is below the water line wouldn't it just put water in the tube? It could be used for a fan controller.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-11-2009, 06:15 PM   #20
texanidiot25
Eat My Rust
texanidiot25's Avatar
The stock mounts will work with some work. What we did is cut the rubber isolater down some so that the mounts would hold it flat against the top of the radiator. Then the filler neck side had to be cut to clear the cap. Once done, the top mounts sat flush with the radiator and it looks good.
Mine is a 4 core version, cools like a mother.
texanidiot25 is offline   Reply With Quote
Old 02-13-2009, 02:28 PM   #21
my67chevytruck
Under Construction
my67chevytruck's Avatar
I emailed the Ebay Seller about the extra port on the passenger side, and this was his comment....
That would be a heater return.
It's there if you need it but if you don't you don't have to hook it up either and it'll still work fine.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-13-2009, 03:21 PM   #22
rob32472
150.00 shipped?
rob32472 is offline   Reply With Quote
Old 02-13-2009, 06:43 PM   #23
OARNGESI
OARNGESI's Avatar
Pm sent
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-17-2009, 11:51 AM   #24
CDA 455
CDA 455's Avatar
Originally Posted by OARNGESI View Post
Pm sent
You have a PM.
DIY4X
Old 02-18-2009, 09:54 PM   #25
CDA 455
CDA 455's Avatar
Ttt
DIY4X
