BlahBlahBlah
4HI vs 4LOW
Although Ive owned 4x4's in our style trucks for years I seldom put them in 4 wheel drive. Once in a while to get out of a muddy spot or something.
Today I was jonesing for a Mt Dew and since my Scion is buried in the snow the only way I was going to get one was to take my K20 in to town. I locked in the hubs and stuck it in 4Low to back out of the garage and up the small slope that is my driveway. Only my rear wheels were spinning. Couldnt get up the driveway. I put it in and out several times...no go. So I stuck it in 4Hi and backed right out. Everything worked liked it was supposed to. I stuck it back in 4Low, and once again the fronts didnt lock in. My question is, whats happening here? Do I have a hefty repair bill in my future, or maybe its just a matter of a linkage adjustment. Any help is appreciated. Last edited by CG; 12-18-2008 at 05:10 PM. |
Re: 4HI vs 4LOW
When you put it in 4low did you notice a reduction in gearing?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
BlahBlahBlah
Re: 4HI vs 4LOW
I just noticed that the front tires weren't spinning, you could feel only the rears were doing the pulling. And when I put it in 4Hi it drove right out.
#4 | |
Re: 4HI vs 4LOW
Even if the fronts arent turning you should notice a reduction in gearing. If it doesn't feel like it is in a lower gear then it might not be shifting into 4lo at all, either internally (??) or the linkage is messed up. If it does lower the gearing then something internally with the front output/gears is messed up.
Re: 4HI vs 4LOW
Mark,
It is telling you that you need to pull out the 4spd/np205 and swap in your TH350/np205. Sorry to hear that it doesnt seem to be working correctly. I would shift it into 4 low (with hubs not engaged) and see if you can turn the front driveshaft by hand. If you can something is wrong with the transfer case. I would check the shifter, see if it is hitting the body or if it is not moving the rods on the transfer case correctly. I hope you figure out the problem.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
#6 | |
Bloo
Re: 4HI vs 4LOW
sounds like the t-case has internal problems to me; there should be a very notable difference in wheel speed in 4-lo, even if the front wheels dont turn
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
BlahBlahBlah
Re: 4HI vs 4LOW
The problem with trying to notice wheel spin speed or lower gearing when only the rears are turning is that basically they are spinning on hard packed snow and ice. I might as well have the thing jacked up in the air in back...plus like I said, I almost never use the 4 wheel drive so it might just be I dont have enough experience to "feel" these things like most of you 4x4 guys.
Eric give me a call when you wanna come down and help me swap that stuff out...lol. Actually you should call me anyway I have a question about the cab on your 4x4. |
Re: 4HI vs 4LOW
i would try what eric67m said and keep the hubs unlocked and put the t-case in 4LO and see if the front driveshaft spins, also try that with four high just to make sure.
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
Re: 4HI vs 4LOW
Mark,
I will give you a call this weekend. My cab on my truck is going to get swapped in the near future. My cab was so rusty.......... how rusty was it? Well the rear cab support bolts punctured the gas tank....... Is that bad?
Re: 4HI vs 4LOW
Hubs locked?
or a non original shift knob telling lies?
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 4HI vs 4LOW
That's what I was wondering... wrong indicated pattern for your t-case?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Feb 2004
Re: 4HI vs 4LOW
I was wondering the same thing, but CG sureley didn't forget to lock the front hubs.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Re: 4HI vs 4LOW
BlahBlahBlah
Re: 4HI vs 4LOW
Wouldnt go anywhere in 2 wheel, just both the rears spinning happily away. Locked in the hubs, stuck it in 4low, same thing with the rear wheels, they just spun. Put it in 4 high, everything worked like it was supposed to....backed right out of the snow and ice.
So I can assume the hubs are fine. Both shift knobs are original. I need to stick it in 4low like was suggested and try to spin the front driveshaft by hand and see what happens. |
#15 |
Re: 4HI vs 4LOW
You do not need to be a 4by guy to know when your truck is in low gear. Once you get to some solid ground put it in what you think is 4 low. Then first gear. It should move R e a l s l o w...... Make sure that low is engaged properly before you look else where. If 4 high is working fine it is fairly unlikely that you would have a major problem with 4 low. anything that catastrophic would likely cause bigger problems. I suspect you are not getting it all the way into low. possibly the low linkage on the t-case has become disconnected??? If a hub was the problem 4 high would have the same issue.
1979 international scout ssII (restored) 1967 k20 4x4 (72 k20 frame and gear with ps,pb) 1969 c2500 GMC 1970 k10 in pieces 67 to 72 swb frame and running gear (project) Last edited by blackscout; 12-22-2008 at 12:49 AM. |
#16 |
Born Psycho
![]() Join Date: Feb 2001
Re: 4HI vs 4LOW
sounds like the linkage isn't pushing the 4 low completely into gear. you don't have a twin stick conversion do you? or as stated above, the shifter is hitting the cab floor and not allowing complete engagement.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#17 |
Re: 4HI vs 4LOW
I agree linkage problem.I`m 99.999999999% sure you have a linkage adjustment issue.It`s rarer than hen`s teeth for one of these cases to have a problem,I can`t imagine 4hi engaging the front axle and 4lo can`t,you`d have some serious shrapnel clunking around,that would have roached the whole thiong in not many miles,and you aren`t in lo transfer because you`d know it.You`d need to be in 3rd or 4th/4lo to come anywhere close to feeling anything like 2nd/4hi.In snow you need momentum and 4hi is what you want.In 4lo the tendency would be to sit`n`spin.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-22-2008 at 02:36 PM. |
