Old 12-02-2002, 07:48 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Unhappy Shroud Installation?
I just found a shroud and can't figure out how to get it past the fan. The fan is a few inches away from the radiator. If I take the fan off it would work but then how do you get the fan back on?. I'm so confused!. Please help. Thanks
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 12-02-2002, 07:50 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You will have to take off the fan. Then it is a matter of skinning your knuckles on the blades while you install the fan back on with the shroud in place. That is the way I have always done it and I can't seem to figure out an easier way. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-02-2002, 07:51 PM   #3
crazy longhorn
Fabricate till you "puke"
Take the fan off, slip the shroud in place, then slide the shroud back toward the eng & bolt the fan back on. Then slide the shroud foward, & bolt it up.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-02-2002, 07:52 PM   #4
slam33
slam33's Avatar
It's called scuffed knuckles. You need to pull the fan and reinstall it after the shoud
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 12-02-2002, 07:53 PM   #5
slam33
slam33's Avatar
look at the post times, we all said the same thing at the same time
</A>
Old 12-02-2002, 07:54 PM   #6
COBALT
COBALT's Avatar
Um...???
Mine was easy (I have a SB 350). You just take the fan loose from the water pump, and take the shroud out with the fan together. Then, when you're putting them back in you have to do the same thing. The water pump pulley is kinda in the way, but you can move it around...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 12-02-2002, 08:26 PM   #7
special70gmc
special70gmc's Avatar
maybe im just screwed up but i always take the radiator out i like taking the hard way i guess. at least no skinned knuckels from the blade.
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-02-2002, 08:26 PM   #8
special70gmc
1958 belair 2door
Old 12-02-2002, 11:37 PM   #9
junkyardjohn
junkyardjohn's Avatar
Lightbulb
I ALWAYS PULL THE RADIATOR FIRST TOO.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-03-2002, 12:05 AM   #10
da-burb
"Ochre Ogre"
da-burb's Avatar
You should look at the size spacer you have between your fan blade and the pulley. W/O a shroud somebody may have put a longer spacer in so it was closer to the radiator. When you get the shroud on, your blade should be 50% to 60% inside the shroud to get maximum air flow. You still get the skun knuckles, no way around it unless you pull the radiator.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-03-2002, 10:33 AM   #11
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Yeah, I left so much skin on my fan when I put it on it was out of balance! lol
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
