"THE GREEN GOBLIN"
Quick wire question
Ok I have two black wires on my wire harness that go over the radiator and to the battery location. One I know for sure goes to the power junction block It feels like a Fuesable link the other Im am not sure if it is ground or Also goes the Battery Junction block Thanks......
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 12-20-2008 at 03:24 PM. |
![]() Join Date: Dec 2006
Re: Quick wire question
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
"THE GREEN GOBLIN"
I looked at this wireing diagram and It only shows the red wire to the juction block but at the block that wire turns Black Now this diagram is for a V8 my wireing is origanaly IL6 Is this the same?
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
The wire with the fuse holder is for the ampmeter. Should be another one on the other side.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
"THE GREEN GOBLIN"
So that wire does go on the Battery positive side of the Junction block aswell? "SO IT IS NOT A GROUND WIRE"
member #16
![]() Join Date: Dec 1999
I marked both 4 amp ammeter fuses on the diagram. No they are not grounds.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
"THE GREEN GOBLIN"
I see it Now I wasn't sure thanks
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
The other one (without fuse in it) is a fuseable link. Goes from
junction block beside battery to the POS terminal on the battery. Basically is a slow burn fuse.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 12-21-2008 at 09:24 AM. |
