Old 12-22-2008, 02:03 PM   #1
olsofti
olsofti's Avatar
A few pics of my '64 5.3
Just wanted to add some pics and show what I've been up to.
5.3 4l60e
Attachment 414377
Camaro tank
Camaro modified rack
2 1/2 Flowmaster Deltaflow 40s
Stock Silverado gauges
New fuel door from a Tahoe
Name:  IMG_gas door0001.jpg
olsofti is offline   Reply With Quote
Old 12-22-2008, 02:04 PM   #2
LuckyHenriksen
LuckyHenriksen's Avatar
Re: A few pics of my '64 5.3
Hey that tahoe fuel door looks good
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-22-2008, 02:14 PM   #3
olsofti
olsofti's Avatar
Thanks man.
It really works good too.I filled up yesterday and it never gurgled once.
I'm using the Camaro filler neck in the Tahoe door.
Old 12-22-2008, 02:24 PM   #4
LuckyHenriksen
If it works good, youve done something right
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-22-2008, 02:29 PM   #5
orange66fleet
Lowered in Cleveland
what did you do to modify the rack and how is it working so far, as always pictures before engine install. It is all looking good so far, and I like the use of the gauges.
orange66fleet is offline   Reply With Quote
Old 12-22-2008, 02:52 PM   #6
olsofti
olsofti's Avatar
The Camaro inner tie rod ends were too long.I used the stock ones from the '03 silverado engine donor truck,the threads were a different size so I turned them down on a lathe and rethreaded them to fit the Camaro rack.
Now here's the secret the outer tie rod is from a mid 90's Ford Ranger,they fit the tie rods and the smaller taper of the spindle arm mount.
I just centered the rack to the truck frame and made sure I had enough movement to avioid bump steer.I made the mounts from square tubing that I split and welded back together to match the taper of the rack mounts.then welded them to the frame.I did this after the engine was in.
It drives really good.The only problem is that it doesn't turn as sharp as stock.It's only been a problem when I have to get in a tight space.I have to back up a little and turn agian.
Old 12-22-2008, 03:21 PM   #7
LuckyHenriksen
Thats pretty creative
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-22-2008, 04:59 PM   #8
hewlett2002000
hewlett2002000's Avatar
looks great!! any chance you could post some more pics? i might be doing this swap soon. again, looking great!!!
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 12-22-2008, 05:21 PM   #9
rayce08
rayce08's Avatar
any more info on the tank , fittment and such ? any pics from the back ?
rayce08 is offline   Reply With Quote
Old 12-22-2008, 08:00 PM   #10
PrerunnerRob
PrerunnerRob's Avatar
Saw that your ABS, Brake, and check engine light are on. Are you runing a re-flashed computer, or a stock one? You can make all that stuff go away and ditch the secondary o2 sensors for under a hundred bucks if I remember correctly.
Any chance I could get a picture of the gas tank from the rear, and see how much it hangs down?
PrerunnerRob is offline   Reply With Quote
Old 12-23-2008, 09:41 AM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good, nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-23-2008, 11:33 AM   #12
TimE
Hey Y'all!!
TimE's Avatar
Great job olsofti! The more pics and info the better. Mine has kinda bogged down (too much other stuff happening) but looking at yours make me want to re-prioritize some things. Keep it up!!!!!
I'm guessing you went with the Camaro rack because the truck rack was too long? Or? The tank is from a 98-02 Camaro? Like PrerunnerRob said, how bout a pic of the tank from the rear? And any other pics you would like to post for inspirational purposes!
TimE is offline   Reply With Quote
Old 12-23-2008, 01:41 PM   #13
olsofti
olsofti's Avatar
Yeah 98-02 tank.?You have to trim the bottom of the frame on both sides to fit the tank.About an inch or so.Then a hole for the fuel hose,worked out great for the fuel door that I wanted.
I made rear hangers so I could use the camaro tank straps.I rebent the silverado fuel lines and used them.The camaro fuel pump and sending unit work if you need the 33-240 ohm like me.
The rack on the silverado was too long and broken.I took a chance that the camaro would be short enough when I bought it off ebay for $3.50.The rack was o.k.,tie rods too long.
Here's a couple more pics;
I found this video;
Old 12-23-2008, 06:58 PM   #14
olsofti
olsofti's Avatar
The engine wouldn't show up in the first post,I'll try agian.
Old 12-23-2008, 07:25 PM   #15
LuckyHenriksen
That install looks clean! I like the first pic, the air intake looks cool
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-23-2008, 10:51 PM   #16
TimE
Hey Y'all!!
TimE's Avatar
Wow! This is a real nice, well thought out package you have assembled. And it looks like the budget wasn't a killer either due to your ingenuity. I am sure I will be contacting you with questions once I actually start moving forward with mine.
Thanks for the extra pics and video, btw.
Old 12-23-2008, 11:10 PM   #17
scotts62
One day...
scotts62's Avatar
Thats awesome!
Wish i could go that setup on mine...hum...
Scott
93 crew cab build
Project 62
Old 12-23-2008, 11:16 PM   #18
TimE
Hey Y'all!!
TimE's Avatar
Aaawwww, go ahead Scott. It's only money. You'll make more next week!
Old 12-24-2008, 11:03 AM   #19
scotts62
One day...
scotts62's Avatar
wana help me tell the wife that
I need to find a cheap truck like you did, you did the easy way verses piecing it together.
Yours running yet?
Scott
93 crew cab build
Project 62
Old 12-24-2008, 02:54 PM   #20
LuckyHenriksen
I was also curious about properly lifting a Gen III
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-29-2008, 03:05 PM   #21
joe231
joe231's Avatar
very cool!
about time you posted pics!
if i could bother you for one more pic....
standing 15 or so feet behind the truck so we can see how low the tank hangs below the bumper.
Thanks, Joe
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-29-2008, 03:44 PM   #22
jchav62
1962 C-10
jchav62's Avatar
Good stuff. Looks awesome. That's the same engine I have in my '04 z71. It must be a runnin' SOB in that '64!!! Awesome work...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-29-2008, 06:43 PM   #23
I like what you are doing with your truck. Gotta watch this build!
Palf70Step is online now   Reply With Quote
Old 12-29-2008, 08:49 PM   #24
olsofti
olsofti's Avatar
Here's one Joe I'll try to take another tomorrow.
Old 12-29-2008, 11:22 PM   #25
joe231
joe231's Avatar
cool, thanks
looks like it is tucked nicely
CHEVY ONLY
