12-22-2008, 08:47 PM | #1 |
1" shackles
where are you guys getting 1" drop shackles all i see is 2" and i already have the flip kit just need the shackle for 7" also what brand shackle does the 1" thanks
12-22-2008, 08:50 PM | #2 |
6.0 powered square
Re: 1" shackles
you could remove some leaf springs
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
12-22-2008, 09:14 PM | #3 |
Re: 1" shackles
I am using my shackles or 1" of drop . Most shackles are 2" but have two holes in them . The top hole is the 2" drop . If you use the second hole , it should only give 1" of drop . If you are only looking for about one inch of drop but want to save a little money , go to a salvage yard and get some shackles from an 88 up chevy truck . They are a little longer than 73-87 shackles and will offer between 1/2" to 3/4" of drop .
Frank
Born and proudly residing in a Red State ! |
12-22-2008, 09:50 PM | #4 |
BAD BOW-Silverado XST
Re: 1" shackles
Remove the large heavy load spring. The drop is almost 1".
12-22-2008, 10:14 PM | #5 |
Re: 1" shackles
12-22-2008, 10:25 PM | #6 |
Happy to be here
Re: 1" shackles
That spring is about 3/4" thick so it is good for a 3/4-1" drop. It is never used unless you put a load in the rear, then it kicks in when the spring pack sits on it.
12-22-2008, 11:37 PM | #7 |
Re: 1" shackles
Not unless you load more than 500 lbs in the rear. I've run mine without the load spring since installing a drop kit. I've also added traction bars. I've carried a 455 Rocket engine without any problems. My truck actually runs better if I have some weight in the bed.
12-23-2008, 12:03 AM | #8 |
Re: 1" shackles
i have a flipkit so would i still get about an 1" from removing the load spring?
12-23-2008, 12:07 AM | #9 |
6.0 powered square
Re: 1" shackles
yes, and a better ride
12-23-2008, 12:12 AM | #10 |
Ephesians 2:8
Re: 1" shackles
So if he has a flip kit ( axle on top of springs ) removing the 3/4" thick bottom spring will drop another inch?
I am going through similar motions with my Big 10. It has 7 springs per side, don't need some... Removing the thickest and adding a 2" drop shackle should gain me about 3" of lowering. I think...
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
12-23-2008, 12:23 AM | #11 | |
6.0 powered square
Re: 1" shackles
same setup with a flipkit there was no axle travel it might of been a better ride with shock extenders and a bigger notch
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 12-23-2008 at 12:33 AM. |
12-23-2008, 12:14 AM | #12 |
Re: 1" shackles
with a flip kit isnt the load spring on the bottom of the spring pack and the rear on top of the springs.. I guess the spring pack settles some when you remove the load spring. Am I correct?
