12-24-2008, 12:24 AM | #1 |
53 Bed to Frame mounts
After setting up the bed for my 53 and placing it back on the chassis I noticed that the frame was shorter to the rear of the bed mounts.
I was under the imperssion that all 47 to 53 frames for the short bed were the same. I started this as a "new" to me chassis for a 47 to 53 but after installing the bed it seems to be 1 to 2" shorter.
12-24-2008, 02:20 PM | #2 |
Re: 53 Bed to Frame mounts
mine isn't that much better i don't know why but the frame rails don't extend much past where there attached to the bed. your bed dosen't look like a long bed either so long as you can bolt the bed down you should be fine... unless your planning on big heavy loads
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
12-24-2008, 03:09 PM | #3 |
Mine was right on. You or someone didnt happen to shorten the frame a little huh?
12-24-2008, 05:38 PM | #4 |
The frame was a roller when I got it and all I did was check it from corner to corner and it was within a 1/8" so I bought it.
I will extend it a few inches and mount the bed where the front mounts fall and make new rear ones. Thanks for helping solve the mystery!!
