Old 12-24-2008, 10:36 AM   #1
AWEGS72
AWEGS72's Avatar
Barn find '72, first solo project
I've been a member on here for a while, but haven't posted in a long time. I haven't started a build thread yet either. I found this truck looking for some wood for a gun cabinet. A friend of a friends restored an old barn and had some old barn boards. I saw this truck and had to have it. I picked it up for $1800. He had it for 14 years and only really drove it for 3-4 out of those. The rest of it was stored inside. When I bought it I was truck nuts and started buying stuff for it(not a great idea). I ended up burning myself out. I put on new exhaust from the headers back,new lights, lowering spindles,de-arched the leaves,and bought lowering shackles. I put new brakes(brembo) up front and rotors. New dress up parts under the hood....etc, you get the picture. Its been sitting in my garage for the last year and a half. I've tried selling it but it wasn't selling. So I figure I might as well work on it since I can't sell it. I've been pacing myself this time. And only allowing myself small amounts of time on here. I enjoy working on it and don't want to burn myself out again.
Here are the first set of pictures showing the before state as I bought it.
AWEGS72 is offline   Reply With Quote
Old 12-24-2008, 10:40 AM   #2
AWEGS72
AWEGS72's Avatar
More before pics. Both rocker panels need to be replaced but the Right side shows through. There is some rot on the bottom of the tailgate. I'm up in the air as to if I am going to put a CD player or leave the dash uncut. I know leaving the dash uncut is probably the best.
Old 12-24-2008, 10:43 AM   #3
AWEGS72
AWEGS72's Avatar
The under cab took the brunt of the rust destruction. All four of the cab supports need to be replaced. I will most likely need the typical patch panels for the floor,front and rear. Cab corners will most likely follow.
Old 12-24-2008, 10:46 AM   #4
AWEGS72
AWEGS72's Avatar
Here's the rest of the before pictures. You can see that stake pocket is mangled, and both bedside tops had almost a dozen drilled holes on the top. The engine is stock, ugly. The PO painted the whole underside red. I think this saved the wheelwells and under the box.
Old 12-24-2008, 10:51 AM   #5
AWEGS72
AWEGS72's Avatar
Now for the fun stuff. I took the bed off and replace both leaf springs, both had broken leaves in the packs. I installed 2" lowering shackles. The PO had 3" lift blocks. I had the springs de-arched 2" for a total drop of 4". I don't have pictures of it but I installed 2" lowering spindles for the front to complete the 2/4 drop. I like this look a LOT better.
Old 12-24-2008, 01:38 PM   #6
AWEGS72
AWEGS72's Avatar
This is what I looks like after the 2/4 drop, clear lights,and new grille. I put a new roll pan on the rear but took back off to remove the box side.
Old 12-24-2008, 11:04 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Barn find '72, first solo project
Glad to have you back!
It looks like you found a real nice project to start on. Good luck with the rebuild!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-24-2008, 12:31 PM   #8
OARNGESI
OARNGESI's Avatar
Nice project are you gonna keep the roof lights
OARNGESI is offline   Reply With Quote
Old 12-24-2008, 02:03 PM   #9
AWEGS72
AWEGS72's Avatar
I am in the air on the cab lights. I don't want to warp the roof by welding all the holes shut, but I don't really care for them. There is a CB whip holder bolted to the center of the roof too,but I like the clean look. Either way they need to come off for paint, they might just stay off when I get that far.
Right now I'm working on the box, because it has the least amount of work to be done on it....I think.
Thanks for looking, and the encouragement.
Old 12-24-2008, 02:47 PM   #10
LuckyHenriksen
LuckyHenriksen's Avatar
Nice truck, I like the revamped front end with the lights and grille. And the motor looks great with the edelbrock goodies
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-24-2008, 05:48 PM   #11
jljohnson3579
I'm here 2 learn!
jljohnson3579's Avatar
Great job. I like what you've done with the engine. I'll probably go the same route.
This is a great place!
jljohnson3579 is offline   Reply With Quote
Old 12-27-2008, 12:12 AM   #12
AWEGS72
AWEGS72's Avatar
The spark plug wires were compliments of the PO. I just haven't gotten around to fixing them yet.
Old 12-24-2008, 06:41 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
As far as cutting the dash for the radio, why not ? Look at it this way, all the trouble you're going to to repair the rust with welding and all, why not cut the dash? If these trucks ever become that collectible, you or the next owner could always weld the dash hole back up original. As soon as the demand for uncut dashes arises, the aftermarket will start selling dash patch panels just like they sell rockers and cab corners nowdays.
As to the cab lights, you could do like I did to my stepside (used to be a 1 ton dually)...
flat aluminum plate and short stainless steel machine screws...
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-27-2008, 07:58 AM   #14
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Nice truck and build! Hope all goes well.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
