Old 12-25-2008, 07:46 AM   #1
mothertrucker424
mothertrucker424's Avatar
rear locker??
i found a eaton rear in junk yard when i spin the left side forward the right side goes in reverse is this a posi?or just a open rearend?
and how do i tell if its a locker
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 12-25-2008, 01:15 PM   #2
drbyrdman
drbyrdman's Avatar
Re: rear locker??
open
drbyrdman is offline   Reply With Quote
Old 12-25-2008, 01:25 PM   #3
desertrat
desertrat's Avatar
Re: rear locker??
Yes it is an open diff.
I'm not sure if our trucks w/ Eatons every came factory w/ posi.
Also in my opinion posi-traction is not a locker. Someone might correct me but a true locker will not slip and a posi-traction still slips.
As far as I know there has never been a factory vehicle with a locker rear end, since a locker is not always safe to drive on the streets (but it sure is fun).
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 12-25-2008, 04:23 PM   #4
72chevyk10
I built it
72chevyk10's Avatar
Re: rear locker??
if i still have the factory rear i have posi and itl spin the wheels diffrent when theyre off the ground
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 12-25-2008, 05:03 PM   #5
justcuz
justcuz's Avatar
Re: rear locker??
Some Eaton 3/4 ton and GM 14 bolts came with a locker from the factory. In fact I may be wrong but the detroit locker (called a No-Spin) was the only traction aiding device available for an Eaton rear end.
The Eaton automatic locking differential also locks. It is a combination of a locker and a limited slip. It has friction discs that tighten up and lock the rear wheels together when the difference in axle speed is over 100 RPM, however it unlocks at speeds over about 20 MPH. This rear end is commonly called the Gov-lock because of the flyweight mechanism that engages the friction discs.
This is a simplified explination, there is a better one on youtube.
justcuz is offline   Reply With Quote
Old 12-25-2008, 05:15 PM   #6
desertrat
desertrat's Avatar
Re: rear locker??
I didn't realize lockers where that high tech back then. Looks like I need to do some learning
Old 12-26-2008, 10:03 AM   #7
LONGHAIR
Re: rear locker??
This is a simplified explanation, there is a better one on youtube.
I'm afraid that you have combined a few things here....
The Eaton axles (HO 52 and HO72) did indeed have "No-Spin" differentials (Detroit Locker) and that was the only traction-aid available in them. AFAIK though this does not apply to the 14-bolt corporate axle though.
Early 12-bolts had a clutch-type Posi-traction that was similar to the car units.
The Gov-lock replaced the older clutch-type posi-traction in newer 10-12-14 bolt GM corporate rearends.
The "Gov-lock" is just an overly complicated clutch-type posi-traction unit. It does NOT lock....it just supplies a bit more pressure to the clutches as it engages. It operates more like and open differential that can "turn into" a posi-traction ans needed. They are way to complicated, with too many tiny moving parts....inside a very stressed part of the driveline. It's called "Gov-lock" because that is the name the manufacturer gave it....GM called it by an option code (G80) They are inherantly weak. With a totally stock and gently driven truck they can live a long time....but with increased performance, bigger tires, and/or abusive driving...it won't last. When they fail, it is generally catastrophic.
LONGHAIR is offline   Reply With Quote
Old 12-27-2008, 12:08 AM   #8
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: rear locker??
Factory posi's will act like open diffs till RPM increases so in your case it's acting normally.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-27-2008, 10:25 AM   #9
LONGHAIR
Re: rear locker??
That depends upon your definition of "factory posi". Presonally I do not consider a "Gov-lock" to be a "Posi"....it's a "Gov-lock"
Gov-locks can do all kinds of things in the "jack the wheels off of the ground" situation, depending upon the condition of it's guts. This is what makes then "shakey" at best. As 69GMC said, the only ones with any strength are the 14 bolt units. The whole "watch spring" mechanism is just as bad, but the carrier is much more massive.
A "true" posi would have to be totally wasted (clutchwise) to spin backward like an open differential.
A Detriot (No-Spin) can be "unlocked" by hand, which would get one wheel to spin freely, but it can't possibly spin the other wheel backward.
Old 12-26-2008, 05:35 PM   #10
1969 GMC
1969 GMC's Avatar
Re: rear locker??
I agree with what he said ^ but if you are dealing with a half ton axle, I don't know when they went from the clutch style posi to the gov-bomb.
14 bolts did not come with factory detroits unless it is a military cucv truck, which all had them stock. generally speaking, the 14 bolt gov-bomb is the strongest of all the gov-bombs, but I refer to them as gov-bombs for a reason. When they go, they go. At my old job a C3500 dump chassis w/ a gov-bomb decided to give up the ghost and it ruined just about the entire axle. The brakes, wheel bearings, seals, all the bearings in the diff, gear set, and the gov-bomb itself were all trashed because it went. The best thing you can do for a 14 bolt with one is to take it out and swap in an open carrier from another axle, and a detroit.
edit: If you go junkyarding looking for an older chevy with an eaton and the no-spin, they have the G86 rpo, usually just called no-spin. Trucks equipped also get a sticker or a metal tag riveted somewhere inside the cab to let the operator know.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-27-2008, 10:58 AM   #11
Re: rear locker??
The Gov-Loc is actually a ball-ramp design that activates off of wheel speed.It`s the sudden engagement that can hurt them.If they would engage at less wheel spin it wouln`t be a bad idea.I don`t know of anyone playing with that.I guess with other designs out there it makes it not worth trying.
I have a Semi-floater 14-bolt with Gov-Loc in my`91 Suburban with big tires.So far so good.I had a problem with a front hub for awhile and I relied on the limited slip to get that thing full of tools out quite a few times.When I ordered my`92 I didn`t spec a G80 because I didn`t want a limited slip or a posi.I didn`t know anything about the G80 at the time and thought it was a clutch-type.I didn`t want the maintinence.I installed my own Locker.
Old 12-27-2008, 11:52 AM   #12
desertrat
desertrat's Avatar
Re: rear locker??
Sounds complex!
Here is something my simple mind cand wrap around.
Oh yeh, I can understand the complexity of a lincoln locker.
(made a few also)
Old 12-27-2008, 01:27 PM   #13
Re: rear locker??
Let`see,how can I explain it...
Both wheels spin.
Old 12-27-2008, 02:17 PM   #14
LONGHAIR
Re: rear locker??
Both of those ^^^ are bad ideas for street use.
Old 12-27-2008, 03:10 PM   #15
desertrat
desertrat's Avatar
Re: rear locker??
You are correct, but it sure can be fun at times.
Old 12-27-2008, 07:45 PM   #16
mothertrucker424
Re: rear locker??
i opened mine today and when i spin wheel forward then reverse it sorta locks and it snaps/pops?? why?
Old 12-28-2008, 10:59 AM   #17
LONGHAIR
Re: rear locker??
Pictures?
Old 01-03-2009, 12:54 PM   #18
justcuz
justcuz's Avatar
Re: rear locker??
If the snapping and popping you describe, could it also be a clicking type noise? You may have a no-spin aka Detroit locker. The noise is the engagement teeth racheting past each other. Supposedly the locker out of a 14 bolt will interchange with the ones in the Eaton. The difference is the inner axle splines. The Eaton has less splines (17 or 19 I believe) and the 14 bolt has 30 if I remember correctly.
