Old 12-27-2008, 03:19 AM   #1
1969 k/10
1969 k/10's Avatar
fowled plugs
I just got new plugs a few months back and i pulled them today because it was missing and they were black. They were fouled and one of the plug tips was bent and almost just touching causing almost no gap.I don't know what could have caused this. For now i replaced the plugs for some hotter ones and am going to see what happens. What could be causing them to foul?
1969 red k/10 with sb350
4.11 gear ratio, front disk, 3 speed automatic
1969 k/10 is offline   Reply With Quote
Old 12-27-2008, 07:48 AM   #2
cdowns
cdowns's Avatar
Re: fowled plugs
chickrns are fowl
fouled spark plugs are another animal// is it dry powdery soot black or wet tar like black? dry black powder type of fouling is an overrich condition normally from poorly tuned carb//black tar like is bad rings or valves causing oil fouling
as far as the electrode is concerned ,was probally on installation that it got hit
Old 12-27-2008, 07:57 AM   #3
Re: fowled plugs
This is new to me.I`ve never seen a spark plug affected my ducks or any other fowl.
All plugs looked the same?Wet black or dry black?You are sure the one ws gapped properly in the first place?Did the truck seem to run normal all this time?
It could be carburator adjustment,timing,or week ignition if it`s dry...carbon=unburnt fuel.If it`s wet you`ll prolly find some low compression from worn valvetrain,piston ring,cylinder walls.Does it puff smoke when started or when pulling off after idling?Could be valve seals or guides.
All that said,you may have just had too cool plugs and what you`ve done may be all it took.Is the motor pretty much stock?Any add-on goodies sittin`on top?What plugs did you have and what`s in there now?
EDIT:I sure type slow.There were no replies when I started.
Old 12-27-2008, 08:40 AM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: fowled plugs
Were all of them fowled or only a few?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-27-2008, 09:41 AM   #5
LuckyHenriksen
LuckyHenriksen's Avatar
Re: fowled plugs
Haha I was thinking about birds too
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-27-2008, 05:45 PM   #6
1969 k/10
1969 k/10's Avatar
Re: fowled plugs
Haha i feel dumb now, but anyways they were all FOULED and it was a wet black. It it possible that i smashed the plug on installation causing it to bend. ?The timing is at 8 degrees and the plugs were autolites that were already 1 step hotter. As far as goodies i just have an Edelbrock carb. and intake
Old 12-27-2008, 05:56 PM   #7
cdowns
cdowns's Avatar
Re: fowled plugs
do you have a properly installed PVCsystem?
Old 12-27-2008, 05:59 PM   #8
Boog
laying low
Boog's Avatar
Re: fowled plugs
You put you some AC plugs in there and give that carb some attention and I bet it smoothes right out.
Make sure the choke is operating right.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-27-2008, 07:21 PM   #9
Re: fowled plugs
I`d definately be chicken the pcv/crankcase venting.Is it gobbling alot of fuel?A quacked ring would cause such a problem but not all cylinders at once.Same with valvetrain.Duck under the hood and chick how hot the spark from the coil is.I egrit I`m not closer.If you were heron the east coast I`d come over and have a looksee.Is it puffin any smoke?I`d peep in my mirrors while it`s running.When you goose it off idle and it smoked it`s your guides or seals from no lead.
Old 12-27-2008, 08:19 PM   #10
heavy70
heavy70's Avatar
Re: fowled plugs
I agree with Boog hei put r45ts, points put r44t!!!
heavy70 is offline   Reply With Quote
Old 12-27-2008, 11:38 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: fowled plugs
I used to have problems with plugs fouling on my 350. Carb was running rich (Edelbrock 1406), so I changed to an Edelbrock 1901. It was immediately a leaner-running carb, that forced me to add a heat shield to the starter solenoid. It has headers and an HEI. Changed distributors when the GM junkyard HEI broke a wire to the reluctor within the distributor. Changed plugs to AC Rapidfires and have never had another plug to foul....oil or gas-related. Timing on my engine is set to 10-degrees BTDC.
Member Nr. 2770
Old 12-28-2008, 09:37 AM   #12
caminokid
Chevy nut
caminokid's Avatar
Re: fowled plugs
Chicken?? Do you think the PVC has gone FOWL?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-29-2008, 12:08 AM   #13
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: fowled plugs
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 12-28-2008, 01:20 AM   #14
tim21391
tim21391's Avatar
Re: fowled plugs
the people i work with at autozone they said bosch plugs foul up real quick... the ones that only have the one prong..they say those arnt to good... but other then that i dont know
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 12-28-2008, 09:29 AM   #15
LuckyHenriksen
Re: fowled plugs
Hmmm
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-28-2008, 09:35 AM   #16
caminokid
Chevy nut
caminokid's Avatar
Re: fowled plugs
I have found that the older...I should say higher mileage motors....tend to foul plugs. I was always buying the cheap plugs. I started buying the more expensive plugs...getting away from the AC's and Autolites. I wasnt changing plugs as often.
Old 12-28-2008, 10:35 AM   #17
Re: fowled plugs
^Did you miss the rest? If they`re wet,it`s water fowl.I edited in bold type.
Since they are wet,are they oily or smell more like gas?If it`s gassy smelling then I`d look at plugs,carb,etc.If they are oily it`s engine wear.I hotter spark and leaner carb helps compensate,but not the solution.
BTW,Bosch is one of the best products in the world.Which non-qualified person did you speak to at Autozone?Bosch may very well be the best aoto electrical company in the world who know only makes premium products.I just like an American name in my American stuff.Don`t run Oriental name tires either.ACs have been doing the trick since day one for me.You just need the right ones.If which plug you use makes that much diferent,you have bigger problems anyway.
Old 12-28-2008, 01:39 PM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: fowled plugs
When I was selling auto parts at Auto Shack (a while back, right?), I learned that there are parts people who will perpetrate a lie, based on what someone told them to be gospel truth.
Each and every one of us knows someone who we trust to always know the answer to our questions, yet there will be times when their answer may not be totally correct.
How well any spark plug performs in an engine is going to be relative to the state of tune and the overall mechanical condition of the engine. It doesn't matter if it's a lawn mower engine or a AA/FD. Reading the condition of your spark plugs is a science that the engine pros use to help the "big boys" out-do the competition....whatever that competition may be and whoever the competitors are.
Member Nr. 2770
Old 12-28-2008, 09:50 PM   #19
caminokid
Chevy nut
caminokid's Avatar
Re: fowled plugs
I did miss the rest Tim!
Old 12-29-2008, 12:05 AM   #20
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: fowled plugs
[QUOTE=special-K;3050364]^Did you miss the rest? If they`re wet,it`s water fowl.I edited in bold type.
BTW,Bosch is one of the best products in the world.Which non-qualified person did you speak to at Autozone?Bosch may very well be the best aoto electrical company in the world who know only makes premium products.I just like an American name in my American stuff.Don`t run Oriental name tires either.ACs have been doing the trick since day one for me.You just need the right ones.If which plug you use makes that much diferent,you have bigger problems anyway.[/QUOTE]
And what problem would that be?
I just don't like throwing my money away on cheaply made sparkplugs, regardless of who makes them.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 12-28-2008, 01:40 PM   #21
truckdude239
truckdude239's Avatar
Re: fowled plugs
post some pictures of the plugs and we can tell you what is goin on
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-28-2008, 01:51 PM   #22
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: fowled plugs
In the Back of almost any "Hayne's" manual there is a chart that will be the beginners guide to reading spark plugs.It is a good place to look to help learn which plug fowling problem you are having.
BTW is your shotgun a full choke model?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-28-2008, 02:30 PM   #23
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: fowled plugs
Here is a guide to spark plugs and compression that I have found very useful.
If your plugs are black, Your engine is too rich or burns a lot of oil.
I hate to break it to you guys, but NGK and Bosch are the #1 spark plugs out there. All brands are close in comparison, but based on the amount of research and development conducted, NGK and Bosch are by far the best.
This link is useful too. http://www.sparkplugs.com/
Here are the recommendations from edelbrock. I believe the plug seats are flat, so you should use the washers (if they are tapered seats, you don't use the washer...)
Under 9.5 to 1 Compression
Champion ---------- RC12YC / 2071
NGK --------------- FR 4 / 5155 OR BCPR5ES / 6130
Autolite ------------ 3926
Motorcraft --------- AGSFP52
Accel Shorty ------- 0416S
Up to 10.5 to 1 Compression
Champion ----------- RC9YC / 2075
Autolite -------------- 3924
NGK ----------------- FR 5 / 7373 OR BCPR7ES / 3330
Accel Shorty -------- 0414S
11 to 1 Compression
Champion ------------ C63YC / 796
NGK ------------------ R5672A-8 / 7173
12 to 1 Compression
Champion ------------- C61YC / 785
NGK ------------------- R5672A-9 / 7405
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 12-28-2008, 04:30 PM   #24
Boog
laying low
Boog's Avatar
Re: fowled plugs
NGK or Bosch? Nah. Edelbrocks' choices are his opinion or those of his employees.
We all drive GM products here and GM has long used AC Delco brand parts. I have to believe considerable research was done before GM chose this brand. They are made to GM's standards. I have used only a couple of other brands once or twice in my many years but have always came back to AC. The AC plugs in my 2 97 trucks are said to be good for 100,000 miles. From the looks of them I believe they will do that and more.
In the end I feel like if AC is good enough for the General it's good enough for me. That's my opinion on it!
Boog
primer is finer
Old 12-28-2008, 11:54 PM   #25
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: fowled plugs
I have all GM products with the exception of my wifes KIA, which happens to be one of the best cars I have ever owned. This doesn't make me an outsider as your opinion would suggest. I ran Champion, AC, and Autolite for a while. I switched to NGK because after looking at them and comparing them to each other, NGK was better constructed. The insulators don't crack as easily either. In my experience if you just tweak the insulators on Champion, AC and Autolite, they crack. Yes , I use the right rubber insulated socket. NGK also happens to be the most used sparkplug worldwide.
I love GM just as much as you do, but I got tired of throwing my money away on (in my experience) a cheaply made product. Not the car or truck, the sparkplug. It tears me up when I see and read about how poorly American companies have been managed recently and the corners they have cut. Not just GM either. When these companies put the quality back in their product, I will buy it. (I.E. sparkplugs.)
It's a damn shame too, because GM is making the best vehicles they have ever made in their entire history. Despite the sparkplugs they use, I will always buy GM. As a matter of fact, I am looking at a Pontiac G8 for my wife right now and will probably buy one when I can afford it. If it has anything other than NGK spark plugs in it, I will change them.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
