Old 12-27-2008, 09:46 PM   #1
Daniel 61 Apache
Daniel 61 Apache's Avatar
Suspension question
I have a front clip out of a 85 2wd truck. It has 8 lug rotors. I need 5 lug.
In order to change it to 5 lug what would be needed? I am already planning on purchasing drop spindles, rotors, and calipers so the models of those can vary. What I want to know is:
Question #1 : Will the 5 lug 1/2 ton drop spindles work on the 8 lug ball joints?
Question #2 : If no to #1, then does anyone have any advice to change from the 8 lugger to 5?
Daniel
Daniel 61 Apache is offline   Reply With Quote
Old 12-29-2008, 07:56 PM   #2
Daniel 61 Apache
Re: Suspension question
bump for any help
Old 12-29-2008, 09:12 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I don't think ball joints are different between a 1/2 and 3/4 ton. Cross reference them at the parts store.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 12-30-2008, 12:29 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The ball joints are different...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-30-2008, 02:08 PM   #5
Daniel 61 Apache
Chuck
First off, thank you very much for the reply. I searched forever and couldn't find anything.
Ok. Ball joints are different.
Can I then just buy 1/2 ton ball joints and trash the 3/4 ton ones?
Thanks again for the help.
Old 12-30-2008, 03:01 PM   #6
72 CustomCamper
huh ???
I'm not 100% sure, but I think you can install the 1/2 ton ball joints into the 3/4 ton control arms. If not you'll have to change the control arms to 1/2 ton too...
Chuck
Old 12-30-2008, 03:26 PM   #7
joe231
joe231's Avatar
I don't think you can use the lower arms, believe the hole for the 3/4 ton ball joint is bigger, but you should be able to just swap upper ball joints and use the 1/2 ton lowers......
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-30-2008, 06:19 PM   #8
kelgar50
kelgar50's Avatar
Im planning the same thing to my 3/4 ton.This company sells a 2 1/2" drop spindle that uses the 3/4ton upper and lower ball joints as well as the steering tie rods and they sell for less than $300. They use the heavy half ton 1.25" rotors and your stock calipers.
C-20 ¾ to ½ Ton Conversion 2½" Drop Spindles
Click to View Looking to convert your ¾ ton Truck to ½ ton front suspension? We are proud to introduce the only C-20 to C-10 2½" Drop Spindles available on the market. (disc brakes required).
Over the years, we’ve had many customers with C-20 8-lug Trucks that would like to convert over to the better riding C-10 suspension and change their wheels to either a 5-lug or 6-lug bolt pattern. These new Conversion Spindles allow you to upgrade to C-10 front disc brakes on the ’60-’87 model Trucks, and give you the option of 2½" front Drop Spindles for the same price without having to change your tie rods and ball joints.
http://www.earlyclassic.com/catalog.aspx
kelgar50 is offline   Reply With Quote
Old 12-30-2008, 07:11 PM   #9
Daniel 61 Apache
kelgar50.....You are the F'n man!! I was looking at control arms and feeling so depressed about forking out another $400 bucks....Thanks a million!!
